Toymods » Tech & Conversions » RA23/28 and MX32 (Cressida) hub & stub axle dimensions
ke382TG
RA23/28 and MX32 (Cressida) hub & stub axle dimensions Fri, 03 October 2003 01:42 Go to next message
Hello people,
Basically what I am trying to find out is will an MX32 Cressida hub swap onto an RA23/28 Celica stub axle? I know that the disc/hub offsets are different between them which is why I want to use the MX32 hub. If the stub axles are the same on both then it should work, I think??
Someones wisdom would be much appreciated. I have already visited some local wreckers and no one had the RA23/28 struts to check.
Shane.
Re: RA23/28 and MX32 (Cressida) hub & stub axle dimensions Fri, 03 October 2003 01:48 Go to previous messageGo to next message
According to the illustrious Ed, it looks like you're in luck:
Wheel bearing interchangeability
It doesn't specifically mention RA23/28 in that list, but I know for a fact they have the same stub axle/wheel bearing size as later RWD Celicas.
ke382TG
Re: RA23/28 and MX32 (Cressida) hub & stub axle dimensions Fri, 03 October 2003 04:03 Go to previous message
Cheers Norbie,
Just what I needed to know.
Thanks,
Shane.
Previous Topic:3SGTE Camry Help
Next Topic:Bang for buck
Current Time: Thu Nov 19 22:49:39 UTC 2026
Total time taken to generate the page: 0.0053420066833496 seconds
