Toymods » Tech & Conversions » EFI "flooded" ... engine wont spark **Ma61**
boudan
EFI "flooded" ... engine wont spark **Ma61** Fri, 03 October 2003 04:54 Go to next message
Im having some problems with engine not igniting...
i have recently removed a kill switch that was wired to the fuse box in the engine bay... the wire was red & black stripe...
i taken out all the kill switch wiring and rejoined the wires - it started fine and solved all my problems....
now after putting the dash back in - there seems to be no spark... have I fryed something ?
will the ECU bhuggah up if its rubbing on metal (sitting above the glove box lock)...
can anyone tell me the connection of yellow board behind the passenger kick panel.... is it critcal ? it has started fine with out the male connected.
boudan
Re: EFI "flooded" ... engine wont spark **Ma61** Fri, 03 October 2003 04:55 Go to previous messageGo to next message
PS, very strong fumes from the exhaust as if something has been saturated in petrol - hence the flooded theory ?
Re: EFI "flooded" ... engine wont spark **Ma61** Fri, 03 October 2003 05:28 Go to previous messageGo to next message
have you checked the fuse the switch was near that you disconnected? chances are that's fried (if I'm reading you correctly)
ecu should be fine - it is all insulated, unless you've bared some wires at the back
Re: EFI "flooded" ... engine wont spark **Ma61** Fri, 03 October 2003 06:27 Go to previous messageGo to next message
The ECU doesn't have anything to do with the ignition system, so if you have no spark you should start by troubleshooting the ignition system. Why is there no spark? Make sure everything is hooked up correctly. See if the ignition coil has power, and if not try to determine why not.
EDIT: You said "there seems to be no spark". Did you actually check or is that just a theory? Important information!
[Updated on: Fri, 03 October 2003 06:28]
Re: EFI "flooded" ... engine wont spark **Ma61** Fri, 03 October 2003 06:37 Go to previous messageGo to next message
No Message Body
Re: EFI "flooded" ... engine wont spark **Ma61** Fri, 03 October 2003 07:15 Go to previous messageGo to next message
If you have no spark and the injectors are working fine (as you'd expect would be the case with a 5M, given that fuel and ignition are separate), then there would be heaps of fuel being injected into the engine without being burnt, hence the strong petrol fumes.
I suggest you start troubleshooting at the coil and work your way back to the ignition switch. Obviously you have done something after you removed the kill switch/replaced the dash.
boudan
Re: EFI "flooded" ... engine wont spark **Ma61** Fri, 03 October 2003 12:44 Go to previous messageGo to next message
Thanks, I realised after I had written the post that I shouldnt have posted my speculation.... I do not know for certain that there is no spark, how ever I know there is fuel being injected as the exhaust is pratically dripping petrol ...
I tried cranking with no additional throttle and still nothing..
the kill switch had to be connected to the ignition system, it was connected to a red / black wire in the fuse box located in the engine bay..
I've checked all the fuse links and they are all connected.. when i do connect the black / red wire i get a clicking noise ( i then proceeded to connect it to the positive battery and i got stronger clicking noise) ... so its definetely not a fuse..
I suspect that it might be a lose plug on the ecu.. but if the ecu has nuthing to do with ignition, im proper fucted !
[Updated on: Fri, 03 October 2003 12:44]
boudan
Re: EFI "flooded" ... engine wont spark **Ma61** Sat, 04 October 2003 03:50 Go to previous message
Shocked Mad Mad Mad Mad Shocked
As far as I can tell there must be a loose / broken connection in one of the ECU wiring harnesses...
As soon as I pack the ecu horizontal - engine wont start
When I hang the ecu vertically the connection seems to be re-establish ... it starts very very roughly.
The strong petrol fumes remain... and the exhaust blows a blue smoke and lots of it... I've check my engine oil and there seems to be bhuggah all..
the rough idle dissapears after 10 15 seconds...
IM GOING INSANE... Razz ..
Previous Topic:RT104 LSD {borg Warner}
Next Topic:1JZ into MX83..how hard is it?
Current Time: Sun Nov 1 11:50:42 UTC 2026
Total time taken to generate the page: 0.0050590038299561 seconds
