Toymods » Tech & Conversions » Rebuilding 18rgeu
Shaun
Nelson NZ
Rebuilding 18rgeu Sun, 05 October 2003 08:22 Go to next message
Up to stripping my engine down and was wondering if you guys can tell me wat order to do this in please. I have done the sump oil pick up and all bolt on parts e.g oil filter and manifolds. Just wondering in what order do i do the head chain cover and cams and how i get the cam chain off. Any help much appericated
ChuckLandwehr
Re: Rebuilding 18rgeu Sun, 05 October 2003 11:35 Go to previous messageGo to next message
YPB (youpoorbastard)no one replied yet! Mate I have just finished a rebuild on a 18RG. If you have removed all the external bolt-ons(filter bracket et) that's way cool.
To remove the head: first remove the chain tensioner on the RHand side of the timing chain cover,
Remove the cam cover, remove the chain guide on the top of the head 2X12mm bolts.The only way to get the timing chain off, is to remove the cam gears, don't worry about orientation of these bits as you pull them off, as its all timed when you put it back together. Leave the cams installed. At the front and at the RH side of the head where it joins the block, there will be 2 x 12mm nuts, remove these then remove the head bolts CAUTION undo the bolts in a spiral pattern from the outside bolts to the inside. If you don't do this in this pattern and 1/2 a turn at a time, you risk warping the head. When you are SURE all bolts and nuts/studs that were holding the head on are removed, you will find a couple of locations arould the engine where you can use a pry bar to separate the head from the block. DO NOT try to pry between the head and the block. the head might need a little persuasion with rubber mallet, but you should now be able to lift it off.
That's got the head off, now go and buy a Gregory's or Haynes manual, because your'e gonna need it to pull the rest apart, and to re assemble the bloody thing.
regards Chuck.
Mr DOHC
Re: Rebuilding 18rgeu Mon, 06 October 2003 09:06 Go to previous messageGo to next message
look on ebay for the geniune 18RG book
wil8115
Seattle area, USA
Re: Rebuilding 18rgeu Fri, 10 October 2003 06:45 Go to previous messageGo to next message
philmelvin wrote on Mon, 06 October 2003 19:06
Yup, there was just one on there about 2 weeks ago.
The seller was in OZ and wouldn't ship anywhere BUT OZ. Sad
Re: Rebuilding 18rgeu Fri, 10 October 2003 08:51 Go to previous messageGo to next message
erm... buy from toyota... like $40
glenn
Re: Rebuilding 18rgeu Mon, 27 October 2003 07:09 Go to previous messageGo to next message
I to have an 18rgeu at home that probably needs a good rebuild (found water with oil whilst undoing sump bolt. I have thoughts of putting a 12a rotary inplace of where the motor once lived. Would the 18rgeu go harder than the 12a ????
How much would it cost to rebuild ????
Is it fairly easy ???
omegaman
SYDNEY
Re: Rebuilding 18rgeu Mon, 27 October 2003 08:28 Go to previous messageGo to next message
I've also rebuilt my 18rgeu. I have the toyota manual for 18rg, if you want I can email you the assembly diagram. Sure helped me.
[Updated on: Mon, 27 October 2003 08:29]
Steve M
Re: Rebuilding 18rgeu Tue, 28 October 2003 00:52 Go to previous messageGo to next message
Glen, both motors can be good, it just depends what you do to them, in stock form I would say that the 18rg would be my choice, but then I've only been behind an auto 12a.
Rebuilding an 18rg isn't cheap, ours cost about $2700 to rebuild, but then the engine was a $250 incomplete unknown quantity.
If you can get away with not having to replace all the chain dampers you'll save yourself a few hundred and also a lot of grief. As far as I know, we got the last top damper, and that had to come from a 3tgte, that will tell you how rare some of these part can be.
Pistons are a real bugger to find if you want to replace these, we did.
JP engineering can make them up for you $660/set, they are near my house so if you want more info on that, give me a PM.
glenn
Re: Rebuilding 18rgeu Tue, 28 October 2003 10:42 Go to previous message
thanks heaps for your help steve m it sounds like something I could get my eager little hands into, oh and omegaman if you wouldn't mind, it would be awsome if you could email me that info. If its not to much hassle though. Very Happy
Previous Topic:4AGZE AE86
Next Topic:Starlet Glanza V parts?
Current Time: Mon Oct 26 00:57:40 UTC 2026
Total time taken to generate the page: 0.023695945739746 seconds
