Toymods » Tech & Conversions » 4ag oil cooler
RSSTi
Melb, Victoria
4ag oil cooler Mon, 06 October 2003 08:31 Go to next message
I will be fitting an oil cooler from a Twincam/SX to my 4agze, the kit in question is an oil bypass cooler which directs any oil that has bypassed the filter throught the cooler and back into the sump. i need to know if the standard bypass valve on my engine has to be modified or blocked when i fit the kit?
Vic.
Grega
melbourne.victoria.austra...
Re: 4ag oil cooler Mon, 06 October 2003 09:30 Go to previous messageGo to next message
vic you sure it puts it back into the sump?
i'm setting up an earls cooler up on mine, and, the inlet and outlet both mount to where the oil filter screws in.
one thing i found with mine, is, that if i used the sandwich type from the 100kw motor oil fitting (the thing that the oil filter normally screws to) its too short - i had to use one from a RWD 86kw type as the shaft is longer...if that makes sense...
RSSTi
Melb, Victoria
Re: 4ag oil cooler Mon, 06 October 2003 11:13 Go to previous messageGo to next message
I looked at the setup before i pulled it off the engine, the sandwich plate has only one outlet which is after a valve that goes to the cooler and the line from the cooler returns to the sump.
Vic.
Jonny2TG
Tasmania
Re: 4ag oil cooler Mon, 06 October 2003 11:33 Go to previous messageGo to next message
I am very interested in getting a oil cooler for my 2T-G also. I may have to make the sandwich plate myself. Maybe I will get the 4A-FE setup and modify it. I have looked at the 4A-FE on some AE92's, and they have a sandwich plate. Oil line goes from that via some valve, to the oil cooler, and back to a banjo fitting on the side of the sump.
More info on oil cooler please, and oil temp and pressure gauges. I don't want to kill my new motor.
Where does the oil filter fit in the normal oil circuit? Is all oil filtered? or just some?
TE72_Turbo
Re: 4ag oil cooler Mon, 06 October 2003 11:53 Go to previous messageGo to next message
Jonny, how keen are you on having a thermostat in the cooler system? If you dont need it, then motorsport connections offer very well priced sandwich adapters with 1/2" NPT connections for an inlet & outlet to a cooler. All oil still passes through the filter.
Phil
Jonny2TG
Tasmania
Re: 4ag oil cooler Mon, 06 October 2003 12:15 Go to previous messageGo to next message
I need a water thermostat. But I don't think I need a oil thermostat. Is that what that valve is on the botttom of the 4A-FE base plate? I will need to look at my engine again. Does the oil just go back into the sump after the oil filter? If so, I can have the oil just go from the filter to the cooler to the sump all the time right?
TE72_Turbo
Re: 4ag oil cooler Mon, 06 October 2003 12:30 Go to previous messageGo to next message
If you go for an aftermarket sandwich plate, all of the oil will go through the core, and the filter, then back into the motor, not the sump.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4ag oil cooler Mon, 06 October 2003 15:51 Go to previous messageGo to next message
There's 2 types of oil cooler systems, high pressure or low pressure. With high pressure (the one phil just described above) all the oil flows through the cooler before it goes through the filter & then to the motor, so the cooler & it's associated hoses are under full oil pressure.
With low pressure, a thermostat is used to bypass some of the oil away from the motor & through a cooler & then returns it to the sump, but only when it's hot enough to open the thermostat.
There's good & bads in each system.
Grega
Re: 4ag oil cooler Mon, 06 October 2003 21:41 Go to previous messageGo to next message
my 4AGE is running a 1118 earls adaptor which bolts to the block - this then has a hose which travels to a remote filter mount (ford z9 or std 2T filter) which then goes to an oil cooler mounted up the front. from the opposite end of the oil cooler, oil returns back to the 1118 adaptor on the block.
these setups are not cheap. when you start adding up hoses at over $20 per meter, it gets quite expensive. but worth it in my mind - cheap insurance.
jonny - you could use the 100kw type setup on your 2T - earls say that the 1118 is supposed to fit the 2T - sure it screws into the block, but, its about 2-3mm not wide enough so the rubber seal doesn't seal up. i have one of these 100kw type bypass sandwich things if you're interested - i won't be needing it.
RSSTi
Melb, Victoria
Re: 4ag oil cooler Tue, 07 October 2003 08:24 Go to previous messageGo to next message
BigWorm wrote on Tue, 07 October 2003 01:51
So is the valve on the side a thermostat not a by pass valve?
VIc.
BigWorm
Turramurra, Sydney.
Re: 4ag oil cooler Tue, 07 October 2003 14:35 Go to previous messageGo to next message
It's a thermostat that bypasses oil. Razz
So yeah, it's both, a thermally controlled bypass valve.
RSSTi
Melb, Victoria
Re: 4ag oil cooler Wed, 08 October 2003 07:32 Go to previous message
So i just bolt it on.
Thanks for the info.
Vic.
Previous Topic:Reg Riemer & Lexus AFM/550cc injector conversion for 7M-GTE
Next Topic:Aftermarket ECU's vs Drivability
Current Time: Wed Oct 21 10:00:21 UTC 2026
Total time taken to generate the page: 0.0056369304656982 seconds
