Toymods » Tech & Conversions » need a picture of 3tgt motor?????
gussyboy2
Oxenford/gold coast
need a picture of 3tgt motor????? Mon, 06 October 2003 09:30 Go to next message
i'm after the front two oil lines running across the front of the head(they're the turbo oilfeed lines i think)
i really need to know exactly where they go
any pics r muchly appreciated
gus
TE72_Turbo
Re: need a picture of 3tgt motor????? Mon, 06 October 2003 10:26 Go to previous messageGo to next message
From memory (my 3TG has been gone a while! Smile ) the upper line is water, and attaches to either the throttle body or inlet manifold water fitting (cant quite remember right now) at one end, and the thermostat housing at the other.
The lower line is an oil feed, from the sandwich block (between engine block & oil filter) that runs around the front of the motor to the oil distribution block (part of the thermostat housing) to feed the turbo, and connect with the oil cooler outlet line.
I'll try and find pictures in my 3TG manual.
Phil
CLG
Perth, Western Australia
Re: need a picture of 3tgt motor????? Mon, 06 October 2003 12:19 Go to previous messageGo to next message
You'll also need to check your oil pickup, they differ between oil and water cooled turbos!
c2888
Re: need a picture of 3tgt motor????? Mon, 06 October 2003 16:19 Go to previous messageGo to next message
I'll try and take some tomorrow.
i can't promise you, so busy these days.
in the mean time you can see if you find what you are after here
http://www.alphalink.com.au/~soyracer/ta63/page1.h tml
Daniel
gussyboy2
Oxenford/gold coast
Re: need a picture of 3tgt motor????? Wed, 08 October 2003 08:21 Go to previous messageGo to next message
thanx guys but i really need a pic near the start and end of the lines. my motor doesn't have the metal lines around the front. it has only one and is made of the same material as brake lines.
TE72_Turbo
Re: need a picture of 3tgt motor????? Wed, 08 October 2003 10:25 Go to previous messageGo to next message
Sorry, I cant find pictures, but I can give you a detailed description of where they go if you are prepared to listen Smile
Purple_Beasty
New Zealand
Re: need a picture of 3tgt motor????? Thu, 09 October 2003 09:39 Go to previous messageGo to next message
There is only one oil line across the front of both my 3T-GTE motors, the other is a water line. I have sent you some pics I took tonight (so if you get a message from purplebeasty at hotmail.com it is not spam Laughing Laughing Laughing )
Callum
Re: need a picture of 3tgt motor????? Thu, 09 October 2003 11:50 Go to previous message
Yeah the top one goes to the inlet manifold/throttle body area to warm it up... It goes into one side of TB, out the other side of the TB, then into the bottom of the runners flange area.
The bottom hose is oil, it goes from the sandwitch plate under the oil filter, then into the front of the head around the thermostat area.. It then kinda comes out the other side to oil cooler I think.
Basically what TE72_Turbo said Smile
Previous Topic:Spray painting ~~ HELP !
Next Topic:wet weather tyre recommendations??
Current Time: Sat Oct 17 03:45:53 UTC 2026
Total time taken to generate the page: 0.0088770389556885 seconds
