Toymods » Tech & Conversions » Fuel system Placement: ae86
natez
Fuel system Placement: ae86 Mon, 06 October 2003 10:27 Go to next message
Hey
Converting the car to efi system,
facet low pressure pump
vl turbo pump
1ltr surge tank
now the problem is where the hell do i put it, there looks like there is hardly anyroom underneath near the fuel tank, and i really don't think its legal to have it in the car, in the hatch area.
I want it as close to the tank as i can so i spose under the car, near the diff and all that, but it doesn't look like there is any location there, has anyone got any pictures of there fuel setup actaully in the car... that would be great
Callifo
Gawler, SA
Re: Fuel system Placement: ae86 Mon, 06 October 2003 10:28 Go to previous messageGo to next message
Looking for some info on this too, will be needing it done soon.
SPRINTAH!
Re: Fuel system Placement: ae86 Mon, 06 October 2003 10:34 Go to previous messageGo to next message
i made up a little bracket that bolts up to the chassis almost directly above the diff, the brace thing already has threaded holes in it.
all the rest of my stuff is in the engine bay so i can't help u there.
i can try and get hold of a digital camera if you need me to.
Richard
natez
Re: Fuel system Placement: ae86 Mon, 06 October 2003 10:38 Go to previous messageGo to next message
which parts are in the engine bay,
shindeokure
melbourne
Re: Fuel system Placement: ae86 Mon, 06 October 2003 11:17 Go to previous messageGo to next message
i'm mounting mine near the tank outlet at the back. the surge tank and efi pump is going in the engine bay.. i'm not sure about the legal/safety issues on that, but it seems to be the easiest way to do it.
[Updated on: Mon, 06 October 2003 11:18]
FKN16V
NSW, East Coast
Re: Fuel system Placement: ae86 Mon, 06 October 2003 12:29 Go to previous messageGo to next message
The easiest way i found was to cut open the carby fuel tank, put in pump and baffles off a vn commodore tank, hay presto.
Did need new fuel line, but any carbie to efi needs it.
Upgrades for the fuel pump are endless if i ever need it.
natez
Re: Fuel system Placement: ae86 Mon, 06 October 2003 14:04 Go to previous messageGo to next message
that actaully isn't a bad idea, i can get fuel pumps off VNs in wreckers for like 40 bucks... what kind of flow rate do vn pumps have....
Henn
Rosanna, Melb
Re: Fuel system Placement: ae86 Mon, 06 October 2003 14:23 Go to previous messageGo to next message
I reckon FKN16V is onto a good idea. If I were to do it again, I would try something like that.
I managed to cram everything around the tank, got a Holley blue mounted at the very back on the drivers side, behind the wheel arch and on the outside of the bumper mounting point. Tiny (600ml maybe) surge tank mounted to floor between tank and panhard rod. And Bosch VL type pump also between tank and diff.
All of them are mounted through the floor into threaded alloy plates in the hatch area. It is a total hassle to get at, but hopefully I never have to think about it again.
Hen
natez
Re: Fuel system Placement: ae86 Tue, 07 October 2003 02:10 Go to previous messageGo to next message
with the in tank idea, will i have any problems, with fuel surge, its not a track car, only a street car, so i don't think its going to be a real problem with this sort of setup,
but to me the VN idea, seems the cheapest and the easiest way to go about it...
Re: Fuel system Placement: ae86 Tue, 07 October 2003 02:43 Go to previous messageGo to next message
I'd like to know more about this also.. Would like an intank pump arrangement in my RA28.
Is the baffling any good from the VN? I heard it was quite average.
Yeeehah
Re: Fuel system Placement: ae86 Tue, 07 October 2003 02:55 Go to previous messageGo to next message
hey guys,
i've got my surge tank in the hatch and it bloody stinks of fuel- just remember to use teflon backed fuel hoses or u can get teflon braided hoses. U still get fuel vapour out of the rubber ones.
Just my two cents worth!
Youngy
Eskilstuna, Sweden
Re: Fuel system Placement: ae86 Tue, 07 October 2003 09:14 Go to previous messageGo to next message
Nice one FKN16V.
Have a look here and read the paragraph under surge tanks
http://www.mwmd.com.au/fuel_tanks.htm
Sounds like you can get the lot done just like it came out of a factory.
FKN16V
NSW, East Coast
Re: Fuel system Placement: ae86 Tue, 07 October 2003 11:04 Go to previous messageGo to next message
I was charged $300for the tank conversion, that includes tank, pump baffles, instalation of pump and baffles, plus the pull out and istallation of new tank.
Might be cheaper now.
I get no fuel smells, the pump does have a slit buzz to it but the exhaust note takes care of that.
Im not sure about a vn pump into other tank, trial and error i guess.
I believe the sprinter and vn tanks are the same shape, the vn is a lot deeper thou.
Draw a basic design of your own fuel tank and look at others that will fit the bill, you never know what other fuel tanks maybe similar shape to yours, and maybe the baffles and pump are compatable.
Hope it all works out for you.
EVOSTi
cambo
      no
Re: Fuel system Placement: ae86 Tue, 07 October 2003 11:16 Go to previous messageGo to next message
mate i just slapped a lift pump outside my fuel tank and it runs fine. never had a fuel surge but then again i dont run my tank close to empty as you shouldnt with an efi car anyway. and in regards to changing the fuel lines, im using the stock lines with my gze running 15psi and ive NEVER had fuel starvation problems.
Re: Fuel system Placement: ae86 Tue, 07 October 2003 11:21 Go to previous messageGo to next message
FKN16V - Mate, where abouts did you get those tank mods done? I live on the Central Coast not far from Maitland. Very interested in getting something like this setup shortly.
Youngy - I emailed MWMD to ask about what they can do in regards to an internal pump with functional baffling and surge/swirl pot. Will let you know what they have to say.
EVOSTi - In my AE86 with 4AGE I also just run a hiflow pump cable tied to the tank. Bit of a dodgy setup but it doesn't seem to serge even with a fairly low tank (not that we make it a habbit to get real low). But for boosted applications I'd be much more inclinded to run a proper setup.
Currently my RA28 has a lift/prime pump with a very large surge tank (5L or so!) and a Bosch merc. pump and works well except the surge tank only fits in the boot which is illegal and sometimes on hot days smells a bit.
Joel
EVOSTi
cambo
      no
Re: Fuel system Placement: ae86 Tue, 07 October 2003 12:13 Go to previous messageGo to next message
bah it works fine, its not dodgy (ie cable tied) ive made a proper bracket and it all sits sweet. you have to remember that most things in cars are over engineered. i doubt that in my application the stock piping wont be able to flow enough fuel.
Youngy
Eskilstuna, Sweden
Re: Fuel system Placement: ae86 Tue, 07 October 2003 12:32 Go to previous messageGo to next message
Thanks Joel, that would be cool.
Re: Fuel system Placement: ae86 Thu, 09 October 2003 23:36 Go to previous messageGo to next message
They say :
"We do not usually modify existing tanks. They are usually pressed from steel and have to be cleaned of fuel, cut open, modified and welded back together. You would be better off building a tank from aluminium, Designed from scratch we can include all required baffling as well as an integral surge tank and fuel pump mounts etc. In the end it would be a much nicer job."
Youngy
Eskilstuna, Sweden
Re: Fuel system Placement: ae86 Fri, 10 October 2003 00:29 Go to previous messageGo to next message
Yeah it probably would be a much nicer job, but what does it cost?
That seems to be different from the impression I got from their website, "We can also mount the fuel pump in the surge tank which is useful when you convert an older car to EFI but want to keep your existing tank"
Interesting
Re: Fuel system Placement: ae86 Fri, 10 October 2003 00:38 Go to previous messageGo to next message
Yeah its all a bit contradicting.
I'd imagine a lot of expense in making a tank from scratch.
Would much prefer just to find someone who can cut mine open and put some good baffling & swirl pot with pump mounts in mine.
The finish would then look factory also.
Youngy
Eskilstuna, Sweden
Re: Fuel system Placement: ae86 Fri, 10 October 2003 01:40 Go to previous messageGo to next message
Yeah me too Joel,
So FKN16V where did you get this work done, did you get it done in Maitland by any chance?
FKN16V
NSW, East Coast
Re: Fuel system Placement: ae86 Fri, 10 October 2003 07:45 Go to previous message
Yes it was done in Maitland.
It was organised by the person who installed the motor. I went passed the industrial estate where it was taken and that was the only place that looked like a sheet metal fabrication company.
I believe it was done by a company called "Challen Fabrication" 0249 338 315
Previous Topic:2S bellhousing pictures
Next Topic:13bt => ke55
Current Time: Sat Oct 24 16:20:59 UTC 2026
Total time taken to generate the page: 0.045825004577637 seconds
