Toymods » Tech & Conversions » Skyline rotors into ae86?
_555_
SOR, Perth
Skyline rotors into ae86? Mon, 06 October 2003 12:22 Go to next message
are skyline disc brakes an easy conversion into an ae86?
[Updated on: Mon, 06 October 2003 14:13]
Henn
Rosanna, Melb
Re: Skyline rotors into ae86? Mon, 06 October 2003 14:27 Go to previous messageGo to next message
I doubt it is easy. Depends on which Skyline rotors/calipers and their size. As far as I know the only easy brake upgrade for an AE86 is the japspec vented discs, otherwise you will probably have to change struts. I had big hassles with clearance of disc to steering arm and caliper sticking out too far into the wheel "spokes". Measure it all up before you even think about buying stuff.
Hen
_555_
SOR, Perth
Re: Skyline rotors into ae86? Mon, 06 October 2003 14:30 Go to previous messageGo to next message
Thanks for responding, the only reason I am asking is that I can get some quite large 4 stud discs for free, whould the stud pattern be similar?
Re: Skyline rotors into ae86? Mon, 06 October 2003 23:27 Go to previous messageGo to next message
Stud patterns the same, but I presume you're only talking about the 275mm GTS/GTS-R R31 rotors?
I'm actually working at present on fitting a set of GTR rotors to my ae86, I'll take some pics when I'm done Cool
optionUP
Perth, WA
Re: Skyline rotors into ae86? Tue, 07 October 2003 05:37 Go to previous messageGo to next message
I have rotors and calipers from an R33 GTS-T on my AE86. AFAIK, the only mod was to fabricate new brackets to mount the calipers. I might have also been luck in the choice of wheel I chose, which gives plenty of clearance all round the caliper (15" Speedy Mystique II wheels) - the space between caliper and inside edge of the wheel in about 1cm. Still have bothered gettign the Nissan logo ground off the calipers! Smile
sprinterboy4agze
Re: Skyline rotors into ae86? Tue, 07 October 2003 06:12 Go to previous messageGo to next message
what strut did u use for this and did u fabricate the bracket yourself could u get some pics pls?
Re: Skyline rotors into ae86? Tue, 07 October 2003 06:52 Go to previous messageGo to next message
Fark! I'd love to know about this! I've been trying to fit 300zx (I understand very similar to R33) calipers to all different kind of struts and had NO luck so far!
Any info would be appriciated soooooooo much Smile
Here are some pics of where I am at :
Caliper:
http://members.optusnet.com.au/helenfitz/nissan_calliper1.jpg
Caliper bolted to ST141 strut:
http://members.optusnet.com.au/helenfitz/st141strut.jpg
Where the problems begin : There is NO room for a rotor with a hat. Unless the hat goes over the top of the hub.
http://members.optusnet.com.au/helenfitz/caliper_height.jpg
[Updated on: Tue, 07 October 2003 06:53]
_555_
SOR, Perth
Re: Skyline rotors into ae86? Tue, 07 October 2003 16:06 Go to previous messageGo to next message
Thanks for the info, looks like a good upgrade for sprinter,
it would be nice to see the pics of your brakes optionUp and mrshin!
[Updated on: Tue, 07 October 2003 16:08]
moo4AGZETA22
Tasmania
Re: Skyline rotors into ae86? Wed, 08 October 2003 03:29 Go to previous messageGo to next message
TurboRA28, have you looked at Mitsubishi Evo 4 front rotors. They are 294 or 296 mm, and have a very "flat" hat profile. They're 25mm thick. This may be a bit thin for the calipers though. The disk is 5 stud, and could be easily machined down to 280mm (that's what you want?).
Justin Rolling Eyes
optionUP
Perth, WA
Re: Skyline rotors into ae86? Wed, 08 October 2003 03:35 Go to previous message
I will have the car on the hoist and wheels off in about a week's time, so I will try to get some pics then. No, I didn't do the work myself, but I will talk to the mechanic and find out exactly what was involved.
Previous Topic:Aftermarket ECU's vs Drivability
Next Topic:Intercooler Pipes
Current Time: Fri Oct 23 12:45:37 UTC 2026
Total time taken to generate the page: 0.0043709278106689 seconds
