Toymods » Tech & Conversions » removing timing cover 2TG/3TG
TE72_Turbo
removing timing cover 2TG/3TG Thu, 18 July 2002 07:56 Go to next message
can you remove the timing cover on a 2TG or 3TG without taking the head off?
thanks in advance
Phil
Jonny2TG
Tasmania
Re: removing timing cover 2TG/3TG Thu, 18 July 2002 08:33 Go to previous messageGo to next message
No, not usualy. You also have to take off the sump. The timing cover can be taken off without taking anything else off, but it is tricky and you need to remove the studs in the head and at the bottom where it joins the sump.
inferno
Re: removing timing cover 2TG/3TG Thu, 18 July 2002 12:42 Go to previous messageGo to next message
i have put the cover on without taking the head off, but it still leaked a little from the top since the head gasket was slightly damaged. you would definately have to loosen the sump. I was using a custom timing chain cover gasket which i wedged between the head and the cover.
If you have the cover off i would personally try to carefully get it on without damaging any gaskets before resorting to removing the head, but if your planning to take the cover off, plan to take the head off with it.
TE72_Turbo
Re: removing timing cover 2TG/3TG Fri, 19 July 2002 09:24 Go to previous message
thanks guys, thats pretty much what I thought.
The last 3 times its been apart I've always had the head off at the same time, so its never been a drama.
Phil
Previous Topic:Early corolla: Auto to Manual
Next Topic:Blew up 1st diff in Cressida :(
Current Time: Sun Oct 25 09:01:28 UTC 2026
Total time taken to generate the page: 0.050297975540161 seconds
