Toymods » Tech & Conversions » Gearbox Nightmares
Leighp
NY
Gearbox Nightmares Mon, 06 October 2003 23:38 Go to next message
I cant seem to locate the gear into 1st, sometimes (rarely) 2nd and a nice grind into 3rd, 4th and 5th seem ok to locate.
When at a standstill with foot on the clutch it takes alot of force on the shifter to get into first and then it will clunk in and It seems as though sometimes the clutch is being ridded minorly.
This is a weird problem, and ober the last month or so it has come and gone, any ideas???
Cheers in advance
Cyber-punk
Brisbane, QLD
Re: Gearbox Nightmares Tue, 07 October 2003 00:12 Go to previous messageGo to next message
say hello to warn synchros Smile
Spose its time to think about living with it or getting the box recoed or replaced
When this happened to me i found that if i rode the clutch to idle when stopping it would crunch in a bit easier.
Just wait till it starts popping out of gear under any noticeable load Smile
Re: Gearbox Nightmares Tue, 07 October 2003 00:28 Go to previous messageGo to next message
Sounds more like the clutch isn't disengaging properly, which points to a promblem with the clutch hydraulics. Start by bleeding the system, and check for leaks in the master and slave cylinder.
Re: Gearbox Nightmares Tue, 07 October 2003 00:29 Go to previous messageGo to next message
I second Norbie. If you don't have a hydraulic system, you may want to adjust your clutch cable.
Cyber-punk
Brisbane, QLD
Re: Gearbox Nightmares Tue, 07 October 2003 01:03 Go to previous messageGo to next message
actually
sounds more like it
i shudl really take the time to properly read each word rather tahn skimming
then again....i should be working, not wasting time on here Razz
Jason
Re: Gearbox Nightmares Tue, 07 October 2003 01:41 Go to previous messageGo to next message
Norbie wrote on Tue, 07 October 2003 10:28
I concur Captain Very Happy
Leighp
NY
Re: Gearbox Nightmares Tue, 07 October 2003 02:51 Go to previous message
I shall check those options (leakes) tonight, I have noticed that ever so slowly the hydralic fluid is getting lower, maybe master is the prob
will keep you all posted.
Oh yeah after i posted the origional I drove away with minimal problems and now they are back, When the car is cold it is noticibly worse.
Leigh
Previous Topic:ecu help!
Next Topic:gear box for chaser
Current Time: Fri Oct 23 04:56:56 UTC 2026
Total time taken to generate the page: 0.0645751953125 seconds
