Toymods » General Car Talk » Painting Engine
isaac
Helensvale, Queensland
Painting Engine Tue, 07 October 2003 03:42 Go to next message
Hey, i want to paint my engine. Mainly i want to do the cover on top of the engine and the air induction hose and a few other bits and pieces like the heat shield which gets very very hot. What sort of paint do i have to use, and with the hose and the engine cover, what sort of prepping do i have to do, like do i use any primers and what is the best way to clean before painting. Thanks alot.
coronamark2
Re: Painting Engine Tue, 07 October 2003 03:50 Go to previous messageGo to next message
firstly clean everything you want to paint (properly)
if your talking about your air cleaner (if its metal) take it off clean sand paint with a hi temp paint but if your talking about a plastic/rubber hose dont paint it the rubber will react with it (i dunno cause you havent said what car) and you need engine enamel paint but i have 2 words for you dude OVER SPRAY (you'll meet him soon enough Laughing )
isaac
Re: Painting Engine Tue, 07 October 2003 04:06 Go to previous messageGo to next message
Alright, well my air hose from air filter to engine is rubber, so does that mean that i can't paint it?
I figure that i have to take the engine cover off and then clean and paint it. Is it the end of the world if a bit of paint gets on the inside of the cover? I am assuming yes? How many coats should i do and what primer do i use if any?
Re: Painting Engine Tue, 07 October 2003 05:42 Go to previous messageGo to next message
if you need to ask what happens when you get pain inside a cylinder, I'm not sure you should be removing the head Very Happy
coronamark2
Re: Painting Engine Tue, 07 October 2003 06:05 Go to previous messageGo to next message
If you take it off you will need to put the head gasket back on and retighten the rocker cover not to much or you will crack it, im not 100% sure but seek advice before you take it off or you may fck shit up.if you cant be fkd taking it off (which i couldnt be fkd doing with my brake booster) i just went silly with news paper and masking tape and taped up half my engine bay so then you wont get paint on anything that shouldnt be painted.
[Updated on: Tue, 07 October 2003 06:06]
Re: Painting Engine Tue, 07 October 2003 06:16 Go to previous messageGo to next message
that's a much more sensible idea, unless you have another reason you need to take the head off
'scuse scrambled posts and any offence caused. Thesis is causing mass stress and ruining brain functioning.
Re: Painting Engine Tue, 07 October 2003 06:27 Go to previous messageGo to next message
Um, there's a big difference between taking the head off and taking the rocker cover off guys! You certainly don't need to be a mechanical genius to remove the rocker cover, and then you can take it away and do whatever you like with it without getting overspray all over your car.
Re: Painting Engine Tue, 07 October 2003 06:36 Go to previous messageGo to next message
Norbie wrote on Tue, 07 October 2003 16:27
It's all the same Norbie. You just undo the bolts, and then you just tighten the bolts. No problem! Very Happy
Re: Painting Engine Tue, 07 October 2003 06:37 Go to previous messageGo to next message
*points to said statement about thesis*
I think I should stay out of all tech discussions till that's done, or I'm just going embarass self/give bad advice Razz
isaac
Re: Painting Engine Tue, 07 October 2003 22:51 Go to previous messageGo to next message
Hang on, so that top bit that i want to remove, that has the 4 holes for the spark plugs, and has TWIN CAM 16 written on it, is that the head or is that the rocker cover? Masking the engine bay seems a safer way to do it, but will probably turn out looking bad after it's finished i think. It would be very hard to access some parts of it with the bonnet and other engine components in the way.
crazedrt104
Darwin
Re: Painting Engine Tue, 07 October 2003 23:05 Go to previous messageGo to next message
matre jnust take the rocker cover off and make sure u sand it back good...then get some high temp paint and cover sdaid rocker cover with as many coats as possible....i put about 6 coats on mine(empty can) then stuck it in the oven for an hour...came up shmick
Re: Painting Engine Wed, 08 October 2003 01:49 Go to previous messageGo to next message
the bit with the spark plugs in it is the head. on top of the head, there'll be 2 large metal rectangular bits (which are the bits you want to paint) - they're the rocker covers. you can just remove them and paint
isaac
Re: Painting Engine Wed, 08 October 2003 04:48 Go to previous messageGo to next message
If i did get a bit of paint on the underside of the rocker cover, would it cause any damage? Are they actually part of the engine or just on top of it? Does any body have any pics of their painted engines?
gtman
Re: Painting Engine Wed, 08 October 2003 05:15 Go to previous message
Just don't go crazy with the paint or it might end up like this
http://www.blert.net/ai/i/4motor.jpg
Laughing
Previous Topic:RA28 springs - where to buy?
Next Topic:I bought a TE-72!!! - questions inside!
Current Time: Fri Oct 23 21:39:19 UTC 2026
Total time taken to generate the page: 0.0051000118255615 seconds
