Toymods » Tech & Conversions » hilux diff setup for sprinter
sprinterboy4agze
hilux diff setup for sprinter Wed, 08 October 2003 00:35 Go to next message
i want a hilux diff on my sprinter, ive done some searches
and what i have gathered is that the g series diff is recommended
and that you can get them out of the hilux, hiace and surfs
what specs are hilux LN106
whateva diff you get they have to be modified, shortened to suit the sprinter
i would like know what
1. the ring gear diameter is and what is does
2. what is a gear ratio whats the good and bads
3. what is a pinion? i know the 2 and 4 pinion is used
4. what model to get this stuff from?
5. what lsd is good and not to costly
6. can you mix and match ring gear, gear ration and pinions?
7. do you ppl know any place in sydney where they mod the diffs for the sprinter
this is for a 4agte setup for my sprinter
any help would be much appreciated
Re: hilux diff setup for sprinter Wed, 08 October 2003 08:31 Go to previous messageGo to next message
I personally think a hilux diff is a bit of over kill for a 4agte but anyway.
If you get a diff out of an RN25 or 27 you wont need it to be shortened!
I just got my hilux diff back today after getting TA22 mounts welded on. It cost me $200 which included getting some bearinsg press off some other things.
You can get all different ratios and this will depend on what you want to do.
I think the G series is an 8 inch.
Bout all I really care to know.
[Updated on: Wed, 08 October 2003 08:31]
sprinterboy4agze
Re: hilux diff setup for sprinter Thu, 09 October 2003 23:04 Go to previous messageGo to next message
anyone else??
Re: hilux diff setup for sprinter Fri, 10 October 2003 00:03 Go to previous messageGo to next message
First of all, go to www.howstuffworks.com and read up on differentials. This will give you a basic idea of what a diff is and how it works.
1. Look at pictures of a diff, you'll see what it is straight away. Torque is transferred from the driveshaft to the axles by the crownwheel and pinion. The crownwheel (aka ring gear) is the big gear which goes all the way around the diff. The diameter of the crownwheel is an important factor when determining the load rating of a diff; the bigger it is, the more torque it can handle.
2. The gear ratio is determined by the number of teeth in the pinion compared to the number of teeth in the crownwheel, expressed as a ratio. For example, if 4.1 turns of the pinion results in one turn of the crownwheel, that's a 4.1:1 ratio. A higher ratio (eg 3.5:1) gives you a higher top speed and fewer engine revs on the highway, but you sacrifice acceleration. A lower ratio (eg 4.8:1) will give you zippy acceleration off the line but the engine will rev to buggery on the highway and you'll have a much lower top speed.
3. Once again, look at pictures of a diff and you'll see the small gears in the centre of the diff which provide the differential action. The gears which transfer drive between the axles are sometimes called pinion gears. Most diffs have two pinion gears, but some have four which makes the assembly more rigid and therefore stronger.
4. If you're after a G series diff, any Hilux or Hiace will have one. If you want a specific ratio and/or an LSD centre, you'll have to look for a specific model.
5. The cheapest way to get a G series LSD is to get one out of a Hilux with a factory LSD. You'll mostly find them in later-model stuff (eg most grey-import Hilux Surf's seem to have LSD's). I've seen them go for as little as $400.
6. The crownwheel and pinion comes as a set, but yes you can swap a crownwheel and pinion on to a different centre. People often do this if they buy an LSD and it comes with the wrong ratio; you can pull the crownwheel and pinion off another diff and put it on your LSD centre.
7. Can't help you there.
I agree with Cool1's comments though, a G series diff is big and heavy and not necessary for the power you have. I'd investigate something smaller like an F series.
sprinterboy4agze
Re: hilux diff setup for sprinter Fri, 10 October 2003 00:23 Go to previous messageGo to next message
ok then so where do u get s strong s series diff has anyone done any other kinds of diff rather than the hilux?
sprinterboy4agze
oh and thanx norbie for that
Previous Topic:Emissions evidence for 1G family engines
Next Topic:Tacho Problems
Current Time: Mon Oct 19 10:57:39 UTC 2026
Total time taken to generate the page: 0.053698062896729 seconds
