Toymods » Tech & Conversions » difference b/w different 7m-ge's
ed_ma61
Lost in the K hole
difference b/w different 7m-ge's Fri, 19 July 2002 04:08 Go to next message
just been looking and noticed that the 7mge came out with two inlet manifold/plenum/throttle body configurations.
one has a straight single intake pipe leading to a throttle body mounted on the plenum. the other has the t/b mounted to a Y pipe which then bolts to the plenum.
whats the diff between the two models? performance difference?, which cars did they each come out with, and is there an advantage of one over the other??
ed
TD42T
Mildura
Re: difference b/w different 7m-ge's Fri, 19 July 2002 04:45 Go to previous messageGo to next message
From what I can tell the one with the Y come out in the supra's and the other Which is like the GTE come in the Cressida's.
marty
TD42T
Mildura
Re: difference b/w different 7m-ge's Fri, 19 July 2002 04:49 Go to previous messageGo to next message
Also the Y style has a butterfly in the plenium operated of vacumm which supposidly helps the intake charge get forced into the cylyder through pulses.
Or something like that, can't remember exactly its been a while since I was reading about it.
(man my spelling is bad)
Marty
rob_RA40
c'town, NSW
Re: difference b/w different 7m-ge's Fri, 19 July 2002 05:00 Go to previous messageGo to next message
on the N/A 2JZ-GE the y-pipe is there for the traction control system, the computer controls a butterfly that when needed closes to drop power from the engine.. the other butterfly is controlled by driver..
i dont know if this is relevant but i thought id mention it..
[Updated on: Fri, 19 July 2002 05:01]
ed_ma61
Lost in the K hole
Re: difference b/w different 7m-ge's Fri, 19 July 2002 05:06 Go to previous messageGo to next message
ahh, that bloody TVIS (Toyota Variable Induction System)....
sweet.
ok thanks
TD42T
Mildura
Re: difference b/w different 7m-ge's Fri, 19 July 2002 05:07 Go to previous messageGo to next message
Thats it I knew it had a name!!
marty
rob_RA40
c'town, NSW
Re: difference b/w different 7m-ge's Fri, 19 July 2002 05:09 Go to previous messageGo to next message
hey ed if your looking for some funky TVIS gear, my spare 1G has TVIS.. i wont need any of it as i have a non-TVIS MAP sensor 1G in the car..
ed_ma61
Lost in the K hole
increases top end torque by playing with the harmonics in the plenum. only really good for NA engines. but thats a good thing!
are there any other differences between the two spec's of engine?
ed
ed_ma61
Lost in the K hole
Re: difference b/w different 7m-ge's Fri, 19 July 2002 05:11 Go to previous message
rob: nah mate, not quite at the moment. though if i can pick one up with an engine attached things could be different...
ed
Previous Topic:Blew up 1st diff in Cressida :(
Next Topic:Tamborine in my engine!
Current Time: Fri Oct 23 20:03:16 UTC 2026
Total time taken to generate the page: 0.0062720775604248 seconds
