Toymods » Tech & Conversions » 4agte Injectors... what size is good?
sprinter_turbo
North Brisbane
4agte Injectors... what size is good? Thu, 09 October 2003 01:25 Go to next message
i would like to know what is a good size injector for a turbo 4agze running between 7 to 17 psi?
thank you
dale...
Grega
melbourne.victoria.austra...
Re: 4agte Injectors... what size is good? Thu, 09 October 2003 01:39 Go to previous messageGo to next message
prolly the stock GZE injectors would suffice...
Re: 4agte Injectors... what size is good? Thu, 09 October 2003 01:50 Go to previous messageGo to next message
easy to work out.. go find one of the 'injector flow/horsepower' calculators floating round the net, work out how power you will be chasing, then work out what injector size Smile
oh, and be aware of injector size vs tiem to inject.
80% duty cycle at 8000rpm is only 12ms so you need injectors big enough to do that (or staged injection).
for example, i only need 145cc/min to go to 6000rpm, but for 8000rpm, i need 185cc/min, due to the time available.
ke382TG
Re: 4agte Injectors... what size is good? Thu, 09 October 2003 02:00 Go to previous messageGo to next message
My ZE injectors were ALMOST maxed at 15psi (156rwkw). I didn't want to push the standard injectors right to the limit everyday. I switched to 7MGTE injectors, which flow enough fuel to run over 20psi boost (I only run between 10 and 17psi daily though).
There are a number of other injectors that fit eg 13B Turbo items.
sprinter_turbo
North Brisbane
Re: 4agte Injectors... what size is good? Sun, 12 October 2003 23:09 Go to previous messageGo to next message
cool, i have a few 7m injectors floating around. i will put them in
dale...
optionUP
Perth, WA
Re: 4agte Injectors... what size is good? Mon, 13 October 2003 04:17 Go to previous messageGo to next message
I was told that CA18DET injectors are good for turbo 4AGZE's running around that boost. They are 380cc/min I believe. That's what's on my car; I run 15psi and I think they are at about 75% duty cycle.
TE72_Turbo
Re: 4agte Injectors... what size is good? Mon, 13 October 2003 11:55 Go to previous message
What turbo are you planning to run at 17psi boost? There's more to it than just the boost level....
I run mazda 13B 550cc injectors, they are probably a bit large, at only 75% duty on 20psi with a garrett T28 (S14 200SX).
I've tested CA18DET injectors at 420cc (100% duty, 38psi fuel pressure)
7MGTE "should" be around 430cc
Phil
Previous Topic:21rc questions, more power?
Next Topic:hi flow the CT26 turbo?
Current Time: Sat Oct 24 01:37:14 UTC 2026
Total time taken to generate the page: 0.0049099922180176 seconds
