Toymods » Tech & Conversions » how drivable/streetable would a ae86 with a 4a-gte be?
_555_
SOR, Perth
how drivable/streetable would a ae86 with a 4a-gte be? Thu, 09 October 2003 15:27 Go to next message
I'm contemplating building a 4a gte powered sprinter,
but need to know how realistic this set up would be in terms of drivability on a daily basis? Would it run OK off boost?
CLG
Perth, Western Australia
Re: how drivable/streetable would a ae86 with a 4a-gte be? Thu, 09 October 2003 15:33 Go to previous messageGo to next message
Yep, very do'able. My turboed Celica delivers 9-9.5L/100km, and thats in an older and larger engine, and heavier car. At 110Km/h there is a slight amount of boost going in, but not enough to kick in extra fuel, hence the good figures.
Drivability will also depend on turbo size, I recommend either a brass or ball bearing T28.
_555_
SOR, Perth
Re: how drivable/streetable would a ae86 with a 4a-gte be? Thu, 09 October 2003 15:48 Go to previous messageGo to next message
Those figures are not bad, what sort of power would the
ball bearing T28 give?
CLG
Re: how drivable/streetable would a ae86 with a 4a-gte be? Fri, 10 October 2003 14:10 Go to previous messageGo to next message
Depends on boost! My brass bearing turbo gives 133.3 Rear wheel Hp on 7.3psi, which is the same as the standard turbo boost and power outputs.
[Updated on: Fri, 10 October 2003 14:11]
7M-Brisbane
Re: how drivable/streetable would a ae86 with a 4a-gte be? Fri, 10 October 2003 22:55 Go to previous messageGo to next message
"At 110Km/h there is a slight amount of boost going in"
Um... does anyone else see the problem with this? Your car should not be under load or producing positive boost pressure at a cruise speed like this.
EvilJack
Sutho/Hills NSW
Re: how drivable/streetable would a ae86 with a 4a-gte be? Fri, 10 October 2003 23:16 Go to previous messageGo to next message
Adam who was at Dyno Day has a sprinter puting out 207KW@rw and is his daily driver Very Happy
gabe
Re: how drivable/streetable would a ae86 with a 4a-gte be? Sat, 11 October 2003 02:46 Go to previous messageGo to next message
7M-Brisbane wrote on Sat, 11 October 2003 06:55
Um... I can not see a problem with that. Why cant his car be on boost at that speed??
Re: how drivable/streetable would a ae86 with a 4a-gte be? Sat, 11 October 2003 05:23 Go to previous messageGo to next message
depends on the car & engine. the engine will be under load to maintain a high speed like that, due to friction and air resistance.
we went down to the snow in my mates old n12 nissan exa - and when we stopped in canberra, he mentioned that hed been running on boost almost the whole way down, due to the wind. only a psi or 2, but still on boost. had a pretty glowing red turbo afte rthat too Smile
truenosedan
Re: how drivable/streetable would a ae86 with a 4a-gte be? Sun, 12 October 2003 23:34 Go to previous message
my mate has an 86 gz... whatever soarer and wheather he is on boost or not depends on how far his foot is down Laughing , but doesnt boost also depend on the rpm, so if clint goode has standard diff ratios etc in an ae 86 he would be doing in excess of 3000 rpm at 110 so therefore i see no problem with a little bit of boost at "cruise" it also depends on how flat his foot is.
Previous Topic:suspension for ae86
Next Topic:new turbo for 3tgte
Current Time: Sun Oct 18 11:54:22 UTC 2026
Total time taken to generate the page: 0.0058138370513916 seconds
