Toymods » Tech & Conversions » 18rgeu dummy/balence shaft
Shaun
Nelson NZ
18rgeu dummy/balence shaft Fri, 10 October 2003 02:03 Go to next message
how do i remove this from the block?
Jason
Re: 18rgeu dummy/balence shaft Fri, 10 October 2003 02:35 Go to previous messageGo to next message
Is that the idler cam that drives the oil pump?
If so get a gear puller and remove the gear at the front then undo the two 10MM bolts that hold the flange on to the sandwich plate and there you have it
[Updated on: Fri, 10 October 2003 02:36]
wil8115
Seattle area, USA
Re: 18rgeu dummy/balence shaft Fri, 10 October 2003 06:01 Go to previous messageGo to next message
you mean the lay shaft? that drives the dizzy, oil pump, mech fuel pump? RG's dont have balance shafts.. even if they did it would still vibrate. LMAO!! like above post, gear puller and 2 bolts, remove hold down, comes right out. Smile
[Updated on: Fri, 10 October 2003 06:01]
Mr DOHC
Re: 18rgeu dummy/balence shaft Fri, 10 October 2003 13:23 Go to previous message
i hope u mean remove to rebuild or something like that, u cant remove and discard,,,,,,,,well u can but it wont go well, or at all
Previous Topic:5 spd shifter mods to work with C60 6 spd
Next Topic:Rebuilding 4age 100kw from a SX! Worth it or not?
Current Time: Fri Oct 23 07:49:09 UTC 2026
Total time taken to generate the page: 0.0064139366149902 seconds
