Toymods » Tech & Conversions » tvis problem
SLY16V
camden
tvis problem Fri, 10 October 2003 06:22 Go to next message
hey guys, my friends corolla hasnt been revving its hardest lately so we thought we would try something so my we put my ecu in and it was revving and going perfect then it sort of died in the arse a bit after a while, what i mean is it wont rev higher than 5500rpm....what could this be? i think it has something to do with the tvis not opening, so its staying closed and starving for fuel and air...if the tvis system is the problem would it be the selenoid that is farked or something else?????
cheers guys
SW20R
Re: tvis problem Fri, 10 October 2003 06:29 Go to previous messageGo to next message
check the vaccum sensor (map) but usualy tvis opens at 4400RPM
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: tvis problem Fri, 10 October 2003 06:35 Go to previous messageGo to next message
Having t-vis closed over 4400 shouldn't cause any problems like that, all you should notice is a slight lack in power. It's very easy to just disconnect it completely & try it, if it works fine then above 4400 you'll know that's what it is, but I doubt that'd be it.
IRA11Y
Club Member
Re: tvis problem Fri, 10 October 2003 06:37 Go to previous messageGo to next message
have you checked for error codes? I bet 02 sensor comes up Smile
SLY16V
camden
Re: tvis problem Fri, 10 October 2003 07:07 Go to previous message
havent checked the o2 sensor yet bet thought it could be the problem aswell.....anyways thanks guys
Previous Topic:13bt => ke55
Next Topic:Walbro Pumps
Current Time: Thu Oct 22 22:04:47 UTC 2026
Total time taken to generate the page: 0.0055258274078369 seconds
