Toymods » Tech & Conversions » changing valve stem seals?
pulcino
Mackay QLD
changing valve stem seals? Sat, 11 October 2003 02:00 Go to next message
Is it possable to change the valve stem seals on my gze without taking the head off.If so how?
Re: changing valve stem seals? Sat, 11 October 2003 02:47 Go to previous messageGo to next message
i think this course of action is reffered to in other earlier posts ...
e.g. <http://forums.toymods.org.au/index.php?t=msg&g oto=172432&rid=2087&S=f9060bf5fb7030fd23b7 d3b3812978b6>
...usually involving using air pressure (and piston in right spot) to stop valve dropping down into combusion chamber- when the collets/springs are removed.
it would be safer to pull head off ... plus, if you have to replace the valve stem seals, it's possible that some valve stems are worn ... and while you're there, you might as well give the valve seats a litte grind to help them seal better.
Charles.
Re: changing valve stem seals? Sat, 11 October 2003 05:18 Go to previous messageGo to next message
hope you've got a lot of spare time - apparently takes around 8-10 hours (although I think the site I read that on was relating to a 6 cyl)
IRA11Y
Club Member
Re: changing valve stem seals? Sat, 11 October 2003 06:44 Go to previous messageGo to next message
8-10 hrs Laughing yeah I think theyd be replacing everything else in the engine in that time too LOL
TE72_Turbo
Re: changing valve stem seals? Sat, 11 October 2003 08:08 Go to previous message
That would have to be a full rebuild for sure! I did my GZE on the car in 2 hours from start to finish with a mate to help compress the valve springs while I pulled the valve retainers out. Old seals can be removed with a pair of long nose pliers, just be careful Smile
Phil
Previous Topic:Crown MS5x, RS5x Series Chassis, Body, Engine Manuals free to a good home
Next Topic:Step by Step guide to Changing Blinker fluid
Current Time: Wed Oct 21 13:55:58 UTC 2026
Total time taken to generate the page: 0.005781888961792 seconds
