Toymods » Tech & Conversions » how do I tell if my valve stem seals are shaged
pulcino
Mackay QLD
how do I tell if my valve stem seals are shaged Sat, 11 October 2003 12:38 Go to next message
how do I tell if my stem seals are shaged
ed_ma61
Lost in the K hole
Re: how do I tell if my valve stem seals are shaged Sat, 11 October 2003 13:07 Go to previous messageGo to next message
you blow smoke on high vacuum, and replacing the seals fixes it
Re: how do I tell if my valve stem seals are shaged Sat, 11 October 2003 14:21 Go to previous messageGo to next message
"replacing the seals fixes it"
I love it Smile
seriosuly tho - if youre blowing smoke, change them.
and every other gasket/seal you can find while you're at it
and check piston rings
(if this post makes no sense, I blame thesis)
GTStar
W.A.
Re: how do I tell if my valve stem seals are shaged Sun, 12 October 2003 01:12 Go to previous messageGo to next message
if your valve stem seals are not sealing properly you will find that you will blow black smoke from your exhaust after being idle for awhile.
the seals are cheap to buy, it's the labour that's going to be expensive. trying idling your car for 1 min and then press on the accel.
hope this helps! Smile
Re: how do I tell if my valve stem seals are shaged Sun, 12 October 2003 08:42 Go to previous messageGo to next message
A telltale sign of bad valve stem seals is a puff of smoke on startup which goes away quickly. My 2JZ does this so I'm going to have to replace them eventually. Sad
EVOSTi
cambo
      no
like GTStar said. if you sit at the lights idling and theres no smoke then when you take off there is, thats valve stem seals. if your blowing smoke all the time, probably piston rings.
changing the valve stem seals involves removing the head but in some cases they can be changed without removing the head if you got the right tools for the job (which i do at work).
gold28
Madrid - Spain
Re: how do I tell if my valve stem seals are shaged Mon, 13 October 2003 04:20 Go to previous messageGo to next message
Your motor will give a little puff on start up then clear pretty much instantly. I guess if they are really bad, then you will get it more often. Oil can leak down past a worn seal when the engine is not running, hence the puff during the first start of the day.
If you are seeing smoke while driving it is more likely ring damage. Rolling Eyes
I havn't heard of stem seals showing smoke while the engine is running. I would have thought that the cylinder pressure would prevent the oil entering the chamber. I guess during the induction stroke it is under vacuum. Your seals would have to be really stuffed though to let through enough smoke to notice it though.
rob_RA40
c'town, NSW
Re: how do I tell if my valve stem seals are shaged Mon, 13 October 2003 05:31 Go to previous messageGo to next message
its a shame toyota didnt take into account when engineering the engines that most of them would be sitting in a wrecking yard for extended amounts of time to be then sold off to us aussies Laughing
CLG
Perth, Western Australia
Re: how do I tell if my valve stem seals are shaged Mon, 13 October 2003 05:43 Go to previous messageGo to next message
Shaged? ...Well, they come home late at night, or very early in the morining, walking and smelling funny?!!! Nine months later, they have a baby valve stem seal, and move into surburbia with some guy called Wayne. Laughing Laughing Laughing
They can be replaced without taking the head off. Take a long length of soft rope, thread it through the spark plug hole while the piston is at bottom dead centre, rotate the piston up towards top dead centre, the rope will act as a cushioning stop for the valves. Remove and replace the seals, then drop the piston and retrieve the rope by puling the end you've left hanging out the spark plug hole.
RA28midge
Adelaide and Queenstown T...
Re: how do I tell if my valve stem seals are shaged Mon, 13 October 2003 05:55 Go to previous messageGo to next message
Black or white/blue smoke????????
dingaling
tas
Re: how do I tell if my valve stem seals are shaged Tue, 14 October 2003 16:53 Go to previous messageGo to next message
i see lots of white/blue ish colored smoke pour out of the exuast when i start the car. it eventually goes away. But i don't get to start it much, maybe once a week.
Does this sound like leaky valve seals to you?
I currently have all my cam covers off. I'm gonna retorque the head when i can get the right shaped tool. Also i have valve stem seals, but after reading whats required to replace them, i may just leave the leaky ones in there, until i actually have to take the head off.
gold28
Madrid - Spain
Re: how do I tell if my valve stem seals are shaged Tue, 14 October 2003 21:42 Go to previous messageGo to next message
dingaling: Yup your valve stem seals are stuffed. It is up to you how badly you want to fix them. It isn't really doing too much damage, just keep an eye on the oil level, which of course you are doing anyway.
EVOSTi
cambo
      no
Re: how do I tell if my valve stem seals are shaged Wed, 15 October 2003 11:52 Go to previous messageGo to next message
clintgodde, not ALL valvestem seals can be replaced with the head on, some you definatelly cannot. but the way you described sounds like it would work but still sounds a bit dodgy. the way i do it is with compressed air but not everyone has access to an air compressor. if you do, cut the threaded end off a spark plug, drill a hole through the centre then weld an air fitting on the end. then all you do is screw in the plug and put an air line on it and the cylinder is full of compressed air and the valves cant fall in.
CLG
Re: how do I tell if my valve stem seals are shaged Wed, 15 October 2003 12:28 Go to previous messageGo to next message
Yep, I've never personally done it,but the principle is sound for those applications where it's feasible, without compressed air. Personally I'd take the head off and have it serviced, and while the head is off check for a ridge in the bore too! If you have one, it's time for a rebuild, cos the new head will only make the bottom end worse!
manor
Sunshine Coast
Re: how do I tell if my valve stem seals are shaged Mon, 01 December 2003 11:46 Go to previous message
If you go down a long steep hill without touching the accelerator till u get to the bottom, then accelerate, if there is a cloud of blue smoke from exhaust then, that is stem seals.
If it blows blue smoke continually, it is rings! To change stem seals is easy, the rope is the most effective, compressed air is ok if constant pressure - make sure either way the cylinder u are working on is t. d. c. Cos u can't get the valve back if it drops in, remember top. dead centre, no drop, or head off! Stem seals will prevent about 60% of the smoke, proportionate to the klm's the rings or seals have done
Previous Topic:Threw a timing chain
Next Topic:MA70 speedo dial (aftermarket or is it stock?)
Current Time: Sun Oct 18 03:20:40 UTC 2026
Total time taken to generate the page: 0.0051708221435547 seconds
