Toymods » Tech & Conversions » Low shrink bog?
Gased
icon8.gif  Low shrink bog? Fri, 19 July 2002 14:15 Go to next message
Sure it's not so good to use bog at all and purist and skilled panel beaters can make bent panels flat. For the less skilled many of us resort to a bit of bog (polyester resin).
After beating out a hail damaged car the best I could I used bog. I'v really come to respect the skills of panel beaters. To my dismay after about 8 months the stuff has shrunk back. In most cases the fill depth was at max 2mm and most less than 1mm.
Are there some brands of bog which are better than others?
David
Re: Low shrink bog? Sat, 20 July 2002 04:20 Go to previous messageGo to next message
Could always use fibreglass!
TURBO CALDINA
gold coast
Re: Low shrink bog? Mon, 22 July 2002 08:47 Go to previous messageGo to next message
yes there is if you get it from a paint supply place they will have a good one, nearly all bog will sink back depending on how long you let it dry before sanding it. if it is not that bad you may be able to cut and polish it out
Gased
icon14.gif  Re: Low shrink bog? Tue, 23 July 2002 14:33 Go to previous messageGo to next message
Thanks cool1 & caldina,
After talking to a resin expert I suspect that I used too much hardner.
Also apparently your can heat cure bog after 24hrs of natural cure.
I was told all bog will shrink at least 5%. So I guess it's pretty much impossible to get mirror flat finish that lasts with time.
Fibreglass is a possibility but were talking of small dents. Like the car was hail damaged and I beat them out as flat as I could (but not perfect) - some places couldn't get behind the dent.
Anyway anyone in Melbourne who is going to do fibreglass or carbon or kevlar work should check out RF services (now called Saint-Gobain RF Pty Ltd 03 93290111) at 635 Queensbury St Nth Melbourne and ask for Anton he's really helpful.
David
Re: Low shrink bog? Tue, 23 July 2002 23:01 Go to previous messageGo to next message
For small dents and scratches you could possibbly just use the fibreglass resin! This is what I have been told by some pannel beaters and is also what i'll be doing on my car!
Gased
Re: Low shrink bog? Wed, 24 July 2002 12:56 Go to previous messageGo to next message
Will try most things once - thanks for the tip.
On the bright side it will give me an opportunity to respray in yellow metal flake - should look dazling rather than the ordinary yellow.
Haven't sprayed metalics/flake before.
David
Re: Low shrink bog? Wed, 24 July 2002 13:24 Go to previous message
Let me know how you go wit the flake! I'm very interested! Photos would be good too Very Happy
Previous Topic:4AGE RWD Extractors - Melbourne
Next Topic:Weight - 18RG vs 2TG
Current Time: Thu Nov 19 08:59:59 UTC 2026
Total time taken to generate the page: 0.021828889846802 seconds
