Toymods » Tech & Conversions » differences between igniters? and how do they really work?
icon5.gif  differences between igniters? and how do they really work? Sat, 11 October 2003 16:19 Go to next message
Hey All,
oki, i have a number of toyota ignitors and there seems to be some differences between how they work...
i have a 4 wire internal that hooks up directly to the reluctor and coil, and thats all good.
i have a 4 wire external that hooks up directly to reluctor and coil and that also works. (part number: 89620-10050)
i have 2x 5 wire igniters, part numbers;
89620-12300 (48) (from 4AGE)
89620-14280 (77) (unknown, possibly 22RE?)
the wires for the 4AGE one are fine for power (orange/brown), coil (black), and reluctor (pink and white) and i'm assuming the yellow one is tach output?. oh, and the igniter case is ground.
i believe that the 4AGE one is meant to send reluctor signal to ECU then receive signal back to fire coil.
the 77, i believe was direct reluctor hook-up, no ECU intervention.
for both coils.
when hooked up directly to the reluctor, the coil doesn't fire.
disconnect the reluctor.. then ->
pink wire (to rel) has 0.6v, grounding does nothing
white wire (to rel) has 0.7V, grounding fires coil weakly.
applying a logic signal between 1 and 5V to either white or pink seperately fires coil strongly.
so, does the ECU take in the low level reluctor signal, and then send back a 0/5v logic signal to the ignitor, causing it to fire?
are there any 5 wire ignitors that hook up directly to reluctors?
am i missing something in the reluctor to igniter interface? or should it be that simple?
thanks in advance, Stewart
Re: differences between igniters? and how do they really work? Sun, 12 October 2003 06:04 Go to previous messageGo to next message
IRA11Y
Club Member
Re: differences between igniters? and how do they really work? Sun, 12 October 2003 10:14 Go to previous messageGo to next message
just to throw a bigger spanner in the works Smile ive got a 7 pin ignitor wanna figure that one out for me too Razz
TA22-3SGTE
MACKAY
Re: differences between igniters? and how do they really work? Sun, 12 October 2003 13:28 Go to previous messageGo to next message
Stewart
I have 16 pages of info on all the toyota igniters in PDF format , If you give your email I will send it .
Trevor
Re: differences between igniters? and how do they really work? Sun, 12 October 2003 13:34 Go to previous messageGo to next message
Stewart.. im setting a reminder on my phone now to test how my 5 wire ignitor setup work on the 18R-G.
I might even get fancy and pinch a handheld cro...
Henn
Rosanna, Melb
Re: differences between igniters? and how do they really work? Sun, 12 October 2003 13:51 Go to previous messageGo to next message
Have a look at the Motec webpage - don't know the address off the top of my head.
They have lots of igniter info, usually only in regards to how to wire it up to a Motec suprise suprise, but may shed some light on your situation.
Hen
Re: differences between igniters? and how do they really work? Mon, 13 October 2003 00:52 Go to previous messageGo to next message
ahhh, i forgot about them Smile i know they have a lot of bosch info, but had a few toyotas as well...
will get onto it today!
chrisss
melb
Re: differences between igniters? and how do they really work? Mon, 13 October 2003 12:46 Go to previous message
trev - upload the pdf into the tech docs page on this site. Id be interested in having a look at it as well.
if you cant upload it, then would you mind emailing it to me?
Previous Topic:Little electric fan help
Next Topic:21rc questions, more power?
Current Time: Sat Oct 24 12:39:06 UTC 2026
Total time taken to generate the page: 0.0053768157958984 seconds
