Toymods » Tech & Conversions » 4age & 4agze waterpumps? aw11
Corvid
4age & 4agze waterpumps? aw11 Sat, 20 July 2002 00:14 Go to next message
Im guessing but want to confirm that both of these are the same unit? or is the GZE one different to the GE one?
Thanks,
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: 4age & 4agze waterpumps? aw11 Sat, 20 July 2002 10:56 Go to previous messageGo to next message
Freak i have used the one of my ge on my ze, be warned if you are changing it out of a ze, you have to take the blower off, as well as the crank pulley etc. a easy way about it is just replace the front half (unless it leaks from the o ring) still need to take the crank pulley and plaky covers off though.
Liam
Re: 4age & 4agze waterpumps? aw11 Tue, 23 July 2002 14:00 Go to previous messageGo to next message
Heya,
I am taking the waterpump off my GZE engine at the moment, and putting it on my 4A-F (carby). At Marlows the product code for the 4A-F and the 4A-GE were the same, so they should match up, but oddly enough the code for the 4A-FE was a different one.
Anyway, how can i remove the crank pulley without causing the engine to rotate? The engine is removed from the car and has the gearbox attached.
Regards,
Liam.
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: 4age & 4agze waterpumps? aw11 Tue, 23 July 2002 17:09 Go to previous messageGo to next message
Freak just take the flywheel inspection plate off (underside gearbox/engine) put a flat screwdriver in one of the flywheel teeth so it locks against the gearbox casing so it cant spin in that direction when you undo the crankpulley bolt. (that is how it is explained in the workshop manual too.) then just use a pulley removal tool to pull the pulley off. and put the screwdriver on the oppisite side of flywheel when doing up.
TE72_Turbo
Re: 4age & 4agze waterpumps? aw11 Thu, 25 July 2002 12:48 Go to previous message
why not just put the car in 5th gear with the handbrake on? it wont go anywhere then....
Previous Topic:3tgte bearings???
Next Topic:weight of 4AGE head?
Current Time: Thu Nov 19 21:53:45 UTC 2026
Total time taken to generate the page: 0.0051019191741943 seconds
