Toymods » Tech & Conversions » steering box / power steering recon?
coronamark2
steering box / power steering recon? Mon, 13 October 2003 02:40 Go to next message
My power steering is leaking from the seal on top and various other places as well as my steering box can these be recond or get new seals put in them?
if so or if someone has had this done how much will they flog me?
or could i but a kit and do it my self?
Danners
Central Coast, NSW
Re: steering box / power steering recon? Mon, 13 October 2003 03:26 Go to previous messageGo to next message
The power steering pump in my car recently died and i was quoted $300 to get it reconditioned. I chose the other option of purchasing a second hand pump instead! I just took it to my local mechanic to find out where it should be sent... your local mechanic/power steering guy should be able to give you the same advice
Dan
coronamark2
Re: steering box / power steering recon? Mon, 13 October 2003 05:03 Go to previous messageGo to next message
thanks dude i'll look into it.
Re: steering box / power steering recon? Mon, 13 October 2003 05:55 Go to previous messageGo to next message
If it is just leaking, then you can just replace the seals. If you are happy to remove the box, the seals are held in by a circlip. Take the seal to a bearing shop - it will cost no more than $10. Replace, refit.
coronamark2
Re: steering box / power steering recon? Mon, 13 October 2003 07:04 Go to previous message
so the only seal on the steering box is where the steering column goes in to it?
What about power steering?
Previous Topic:88 Hilux 4X4 V6 conversion
Next Topic:ae86 LSD
Current Time: Fri Oct 23 12:45:24 UTC 2026
Total time taken to generate the page: 0.004371166229248 seconds
