Toymods » Tech & Conversions » Tranny Cooler sizing?
Celia-Sue
Tranny Cooler sizing? Mon, 13 October 2003 03:54 Go to next message
Hey all,
I'm thinking about installing a Serck (sp?) auto tranny cooler in my 1JZ. I'm just wondering about what size to go for? I'm guessing that if is too big I might have problems on cold winter days warming up the box. However, it probably won't be mounted in a good airflow spot (those are reserved for FMIC and radiator). Is the 15 row about right? ANyone have any experience and/or recommendations?
cheers,
Justin
JZA61
Soarer
Wollongong
Re: Tranny Cooler sizing? Mon, 13 October 2003 06:17 Go to previous messageGo to next message
Haven't had any problems with mine. It's 300x200x30mm. Works really well. Gearbox temps are way down on what they used to be. Especially after a hard drive, the box is barely warmer than when idle.
HedgehogSandwich
UK
Re: Tranny Cooler sizing? Mon, 13 October 2003 21:34 Go to previous messageGo to next message
I've got a serck i think (cant remember but 90% sure). It's a 13 row 13x10" on my 1JZ.
Its doing the cooling on its own (no rad cooler) and doing the job fine. Basically i was told the bigger the better if youre fitting a standalone. you can of course go too big and the box wont drop into overdrive.. but it would have to be MASSIVE for that to happen.
MS-75
Re: Tranny Cooler sizing? Mon, 13 October 2003 23:36 Go to previous messageGo to next message
If you are worried about airflow, use some ducting to get extra air to the cooler. Also, I have just finished a fan setup for my transcooler that uses 2 12 cm 12volt fans from dick smith. They are strapped to the cooler like thermos to a radiator, and I have them switched so they come on as soon as the engine oil pressure switch trips out (ie they turn on as soon as the engine is running). I can give you the wiring details if you like. As for being too big-don't worry-as mentioned above you'd need a f***en monster one to keep it too cold!
Sean
Celia-Sue
Re: Tranny Cooler sizing? Tue, 14 October 2003 01:39 Go to previous messageGo to next message
Legends, one and all!
Thanks heaps, guys. Once again, Toymodders to the rescue!
cheers,
Justin
Chris Davey
sunny coast, qld
Re: Tranny Cooler sizing? Tue, 14 October 2003 01:47 Go to previous messageGo to next message
i know nothing about trans coolers but i got mine for free with my car. I have heard there are 2 different types. Mine is about 30cm X 20cm and has tubes going through the fins. It is working 'stand alone'. Will this do the job adequately? I will put a pic up when my damn computer is fixed!
HedgehogSandwich
UK
Re: Tranny Cooler sizing? Tue, 14 October 2003 12:19 Go to previous messageGo to next message
30x20 fin type should be adequate. fin types are easily damaged but offer good cooling.
Heres mine..
http://www.mkiiisupra.net/pics/atfcooler3.jpg
http://www.mkiiisupra.net/pics/atfcooler1.jpg
[Updated on: Tue, 14 October 2003 12:21]
Re: Tranny Cooler sizing? Tue, 14 October 2003 12:22 Go to previous messageGo to next message
that radiator looks sexy!!
how much did it cost you (if you dont mind me asking)
HedgehogSandwich
UK
Re: Tranny Cooler sizing? Tue, 14 October 2003 12:39 Go to previous messageGo to next message
You mean the engine rad? It's a koyo drop in for the JZA70. got it from these guys in the states. www.performanceradiator.com
Cost in AUD is $720 for the rad, plus shipping and import tax, duty etc to the UK it came out at about $1000 AUD (£450 UK).. not cheap. It's also a VERY tight fit in the JZA70. Its nearly twice as thick as stock and 10mm higher.
Re: Tranny Cooler sizing? Tue, 14 October 2003 12:40 Go to previous messageGo to next message
aahhhh
would be cheaper to get one fabbed
HedgehogSandwich
UK
Re: Tranny Cooler sizing? Tue, 14 October 2003 12:41 Go to previous messageGo to next message
http://www.jzasupra.com/pics/rad_2.jpg
Its meant to be mirror finish but i cant get it nowhere near as shiny as my other polished bits... even with a polishing kit.
[Updated on: Tue, 14 October 2003 12:42]
HedgehogSandwich
UK
Re: Tranny Cooler sizing? Tue, 14 October 2003 12:46 Go to previous message
sorry, my mistake... $526 aud. got the address wrong as well.. its www.absoluteradiator.com
shipping is $114 aud, then you have to add your countries tax etc.
[Updated on: Tue, 14 October 2003 12:49]
Previous Topic:Fitting a turbo timer to a RA60/65
Next Topic:PS pumps JZ and UZ whats the diff.
Current Time: Sat Nov 21 01:43:14 UTC 2026
Total time taken to generate the page: 0.0049300193786621 seconds
