Toymods » Tech & Conversions » 4agze CAS wiring diagram
sebta22
4agze CAS wiring diagram Mon, 13 October 2003 05:23 Go to next message
i am wiring up the CAS (crank angle sensor), can anyone tell me what the wiring colours are for this?? or where I can get info?
TE72_Turbo
Re: 4agze CAS wiring diagram Mon, 13 October 2003 11:44 Go to previous messageGo to next message
what ECU are you wiring it up to ?
I may be able to help
Phil
Re: 4agze CAS wiring diagram Mon, 13 October 2003 23:17 Go to previous messageGo to next message
Can't remember the colours off the top of my head, but I do know that if you slip the lid off the thing, it's pretty easy to work it out Evil or Very Mad
sebta22
Re: 4agze CAS wiring diagram Tue, 14 October 2003 02:35 Go to previous messageGo to next message
phil - the ecu is wolf 3d version 4
what type of cas is it?? reluctor (magnetic) or hall effect??
10sec_rx7
Syndey
Re: 4agze CAS wiring diagram Tue, 14 October 2003 03:05 Go to previous messageGo to next message
its a magnetic,
Dale
TE72_Turbo
Re: 4agze CAS wiring diagram Tue, 14 October 2003 08:27 Go to previous messageGo to next message
Yes, it is a magnetic reluctor.
Wires are as follows:
RED: Trigger (pickup for 24 tooth wheel)
GREEN: Home pickup (TDC #1)
YELLOW: Home pickup (TDC #4)
WHITE: Common earth for pickups
Phil
Henn
Rosanna, Melb
Re: 4agze CAS wiring diagram Tue, 14 October 2003 15:37 Go to previous messageGo to next message
For a V4 wolf
CAS white -> TRIGGER GND
CAS green -> TRIG 2, One falling edge per cam revolution
CAS red -> TRIGGER 1, 24 falling edges per cam revolution
TRIGGER +5v is not used since it is a magnetic pickup.
And be sure to set the Wolf to SYNC+REF mode and play with the offsets to get the timing right.
Hen
sebta22
Re: 4agze CAS wiring diagram Wed, 15 October 2003 02:09 Go to previous messageGo to next message
thanks for your help guys
Re: 4agze CAS wiring diagram Wed, 15 October 2003 02:12 Go to previous messageGo to next message
i've been wondering about this...
how can a crank angle sensor know if the engine is at TDC#1 or TDC#1, since it is the same position on the crank...
with a cam sensor it's easy, ,sicnec it does one revolution per engine cycle, but the crank does two revolutions..
so how does it work???
TE72_Turbo
Re: 4agze CAS wiring diagram Wed, 15 October 2003 09:22 Go to previous messageGo to next message
oldcorollas:
The 4AGZE sensor is a CAM angle sensor. It just often gets called a crank angle sensor, i'm often responsible for it Smile, it just rolls off the tongue more easily.
As you said, its not possible to read TDC#1 & #4 with only a CRANK angle sensor.
Re: 4agze CAS wiring diagram Mon, 20 October 2003 03:00 Go to previous messageGo to next message
TE72_Turbo wrote on Wed, 15 October 2003 19:22
schweet, Very Happy thanks for that, i'm not so bonkers after all Shocked
funny how ppl keep telling me that i'm wrong about crank sensor.. sot of.. Sad
Thanks man Very Happy
LBack
Re: 4agze CAS wiring diagram Mon, 20 October 2003 07:31 Go to previous messageGo to next message
oldcorollas wrote on Wed, 15 October 2003 12:12
hi guys, first post in this site...need some help...i have a ze installed in my te72 liftback and lately i'm hearing a ticking sound that is coming from my CAS and becomes faster when my a/c is on...is this normal? if not, can you advice me what do you think is making that noise and how to fix/eliminate the ticking sound. thanks guys!!!
[Updated on: Mon, 20 October 2003 07:32]
LBack
Re: 4agze CAS wiring diagram Thu, 23 October 2003 02:59 Go to previous message
anyone?
Previous Topic:Carb to EFI. Fuel tank question.
Next Topic:Complete front end swap for rack & pinion conversion?
Current Time: Wed Oct 14 09:38:22 UTC 2026
Total time taken to generate the page: 0.042382001876831 seconds
