Toymods » Tech & Conversions » More Brake Questions
Lambolica
Northwestern Sydney
More Brake Questions Mon, 13 October 2003 08:21 Go to next message
I've been stuffing with the drum brakes on the rear of the RA28
do the drums in celicas self adjust over time or do you need to wind out the gear to push the pads closer to drum?
I'm going to do the disc brake thing drums suck.
Anyone have a converted to disc diff for an RA28 they'd like to part with Rolling Eyes I can't weld. Embarassed
Re: More Brake Questions Mon, 13 October 2003 23:13 Go to previous messageGo to next message
The drums do self adjust originally, although lots of them end up getting put together with bits missing so it doesn't work Evil or Very Mad
Drum brakes suck.... Well, they DO, but.. Are you going to do something about those laughable front brakes first? If not, there's really not a lot to be gained by sticking on rear discs... and chances are the handbrake won't work nearly as well when you're done Very Happy
Lambolica
Northwestern Sydney
Re: More Brake Questions Tue, 14 October 2003 02:09 Go to previous messageGo to next message
Yes, but when you way up the cost of some new cylnders, brake shoes, replacing springs etc. and the cost of the disc brake conversion they are very similar(if you find the diff cheap Very Happy ).
And I've got alot of the parts for the front as well. Evil or Very Mad
gold28
Madrid - Spain
Re: More Brake Questions Tue, 14 October 2003 03:22 Go to previous messageGo to next message
The drums/shoes have two actuators, the upper is a hydraulic piston (slave cylinder) this is operated by the foot brake and self adjusts. The lower one is a mechanical lever from the hand brake and needs to be adjusted to take up cable slack.
Lambolica
Northwestern Sydney
Re: More Brake Questions Tue, 14 October 2003 03:28 Go to previous messageGo to next message
So I need to adjust the shoes to within a few mm of the drum so I can get a solid feel to the pedal??
gold28
Madrid - Spain
Re: More Brake Questions Tue, 14 October 2003 05:17 Go to previous messageGo to next message
No, that won't help.
Try bleeding the brakes. The standard celica brakes are pretty ordinary at the best of times, so don't expect too much.
The old brake fluid is probably full of moisture and pretty ordinary. It might be time to give it a full change.
Re: More Brake Questions Tue, 14 October 2003 05:19 Go to previous messageGo to next message
Try pulling the handbrake on slightly and feeling the pedal then - any harder?
Lambolica
Northwestern Sydney
Re: More Brake Questions Tue, 14 October 2003 05:32 Go to previous messageGo to next message
I have just done the brake lines (I lost a cylnder and had to replace it) so I thourght I'd check the drums out and get the handbrake working again. but after putting it all together and bleeding it I'm losing pedal pressure as I'm driving to the point I have no brakes. after the car sits for a while the pressure builds up again.
gold28
Madrid - Spain
Re: More Brake Questions Tue, 14 October 2003 05:34 Go to previous messageGo to next message
Sounds more like a master cylinder
Lambolica
Northwestern Sydney
Re: More Brake Questions Tue, 14 October 2003 06:01 Go to previous message
Yeh that was my guess I've already pulled the master cylinder off the wreck, which was rebuilt recently
Previous Topic:1UZ into a 92 hilux surf
Next Topic:Dumb question - wiper arm removal - MA61
Current Time: Fri Oct 23 15:36:40 UTC 2026
Total time taken to generate the page: 0.036093950271606 seconds
