Toymods » Tech & Conversions » 2TG Problems
batesy
2TG Problems Mon, 13 October 2003 21:28 Go to next message
Hey all,
Just a couple of questions about my 2T-GEU i have...
I have recently put this engine in my TA22 and had to use the 2T engine mousts since the twincam cam out of a T18. Now when i look at the engine it seems to be slanted towards the passenger side about 2 - 3 degrees... is this normal? if not can anyone suggest the problem?
Also I'm using the stock TA22 radiator and i reckon once the plactic fan goes in i'll have about 5mm to 10mm clearance between radiator and fan. I know i should use a thermo but i dont think i'll have the money just yet todo so, so i'm wondering if anyone has come upto this problem before and what i will have todo to fix the fan prob.. (I.E; can i change radiators from T18 to the TA22 or waters pumps etc?????)
Cheers Simon
Snyper
Re: 2TG Problems Tue, 14 October 2003 05:32 Go to previous messageGo to next message
I have always found that the 2tg's I have done always slant slightly to the passenger side.... never effected anything.
as for the radiator fan, thermo's are best, they're not worth that much thesedays, go to a wreckers and pick one up for $20, wire it up. and mount it
batesy
Re: 2TG Problems Tue, 14 October 2003 09:16 Go to previous messageGo to next message
So suppose i get a thermo (which i reckon i will) how would i go at wiring it up?
Would i wire it up as when i switch the ignition on the thermo starts up and doesnt stop until i turn car off?
Or is there a way i can get the thermo to switch off when temp goes down and starts up when it gets to hot etc???
thx for replyin snyper, much appreciated
Simon
ta2272
Re: 2TG Problems Tue, 14 October 2003 10:42 Go to previous messageGo to next message
dont turn it on as soon as ignition turns on because it makes the eniine heat up slower maybe not operating at right temp causing more engine wear.u can buy a switch that automatically turns the fan on they cost around $60 for the switch.
Jason
Jonny2TG
Tasmania
Re: 2TG Problems Tue, 14 October 2003 19:10 Go to previous messageGo to next message
Using the T-18 water pump and fan (3T), this is a viscous thermo fan. It will come very close to the rad. WHich is ok for a bit but once anything twists out of shape the fan will hit the rad which it did in my car. Maybe best to use the old TA22 fan, but to do this you must also use the TA22 water pump. Also, the fixed fan off a 4K motor will also fit the TA22 waterpump. Also you need the matching water pump pully for the fan belt when changing over.
All T motors sit on a slight angle. Look underneath at the stiffener brackets. The bottom holes on each should be horizontal, and you will see each stiffener bracket has a different shape making the block sit on a angle like it should.
juzzo84
Hornsby, N.S.W
Re: 2TG Problems Tue, 14 October 2003 21:16 Go to previous messageGo to next message
there are two different types of 2tg water pumps you can get, the one you want is the shorter neck one, this will give you more room between the waterpump and the radiator!
justin
roger
Re: 2TG Problems Wed, 15 October 2003 01:18 Go to previous message
To fit my 3tgt in I cut the lip off the radator support brace thing to give me clearence between the fan and the raditor. If you are only looking for a small amount then you may get 10mm doing this.
[Updated on: Wed, 15 October 2003 02:30]
Previous Topic:Can anybody tell me what these are for? (7mgte)
Next Topic:Brakes Difference ST162, ST185
Current Time: Sat Nov 21 01:31:23 UTC 2026
Total time taken to generate the page: 0.020071029663086 seconds
