Toymods » Tech & Conversions » 20v head on 16v 4AGE
tortfeaser
Canberra, ACT
20v head on 16v 4AGE Mon, 13 October 2003 23:28 Go to next message
I think I'm about to buy a AE82, but the motor is bung (head gasket, scored bore). The car will eventually be built into a rally car, so I want the 20v box for the ratios, and think the 20v block would be a good idea (strength, compression, oil squirters).
Does anyone know if the 16v head will go on the 20v block? What about pistons?
Its either that or convert to 100kW AE92 motor. But that is pain with the wiring.
Marc
._T_.
Re: 20v head on 16v 4AGE Tue, 14 October 2003 03:14 Go to previous messageGo to next message
it wil bolt on.
i have seen a ae86 running 20v bottom end and bigport head. don't think it was still a non-interferance motor any more though...
T
tortfeaser
Canberra, ACT
Re: 20v head on 16v 4AGE Tue, 14 October 2003 05:37 Go to previous messageGo to next message
Thanks for that. Anyone know any different? Any more info?
IRA11Y
Club Member
Re: 20v head on 16v 4AGE Tue, 14 October 2003 05:58 Go to previous messageGo to next message
yes its still non interferance unless you excessively deck the block and head
if you need to know anymore pm me, ive got some pics if you need as well
[Updated on: Tue, 14 October 2003 06:00]
sjsaman
Re: 20v head on 16v 4AGE Tue, 14 October 2003 07:38 Go to previous messageGo to next message
what about on the 7afe? if that was possable im sure it would be the best modded engine (not including conversion)corolla to date
Matt20v
Richmond NSW
Re: 20v head on 16v 4AGE Tue, 14 October 2003 10:23 Go to previous messageGo to next message
you will need to do a bit of work if u put a 20v head on 7afe as the stroke is diffrent u will lose compression i think if i can remenber right and there are a few other problems to its not just a bolt on job as many think. ur car will hammer through if u did do it Smile
shinybluesteel
melbourne
Re: 20v head on 16v 4AGE Tue, 14 October 2003 10:58 Go to previous messageGo to next message
a mate of mine did this hybrid in his sprinter, bigport head on "silvertop" 20 valve bottom end, worked fine, he didnt mention any problems. dunno if he used 16 valve or 20 valve pistons though.
._T_.
Re: 20v head on 16v 4AGE Tue, 14 October 2003 23:02 Go to previous messageGo to next message
16v head onto 7a bottom end has been done heaps - even runs on stock ecu.
20v head should work.
T
Steve M
Re: 20v head on 16v 4AGE Wed, 15 October 2003 02:37 Go to previous messageGo to next message
Do the 4age pistons have valve reliefs in them?
If you put a 20valve head on a 16 valve bottom end, these wouldn't line up with the valves.
if it is non interference then it probably wouldn't matter but I wouldn't like to think about it changing.
._T_.
Re: 20v head on 16v 4AGE Wed, 15 October 2003 02:58 Go to previous messageGo to next message
4ag pistons have valve cutouts. so do the 20v.
the exhaust pretty much lines up, the inlet sort of does apparently. i have not played with one yet so i really cannot comment as to whether it is non-interferance or not
T
IRA11Y
Club Member
Re: 20v head on 16v 4AGE Wed, 15 October 2003 06:12 Go to previous messageGo to next message
the fly cuts are in the correct position but are not as deep as the 20V piston, i did a quick mock up one day and decided against the effort, but thats not to say it cant be done. the best person to talk to re 7AGE is Jhonny
sjsaman
Re: 20v head on 16v 4AGE Wed, 15 October 2003 10:26 Go to previous message
would a 7a-g/fe fit into a ae82 pretty easily or would it take some work.
Previous Topic:Good source of 2TG, 3T & 4T specs and useful info
Next Topic:ST162 Handbrake Light won't go off
Current Time: Sat Oct 31 16:23:47 UTC 2026
Total time taken to generate the page: 0.11491394042969 seconds
