Toymods » Tech & Conversions » 1JZ Oil Pressure Gauge & Water cooling
Skip
1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 05:08 Go to next message
Got a few more questions:
1. Where can I screw a mechanical oil pressure gauge in? This will be the only one I use. e.g. no warning light or dash gauge. A picture showing the location would help alot.
2. Does the oil pump/filter setup have some sort of water cooling arrangement? I notice water inlet and outlet lines going into it.
3. What does the thingamybob next to the oil filter/pump do? It is gold in colour, has a green connector, and 2 vacuum lines to the manifold.
Cheers Smile
lumpy
Adelaide, SA
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 06:12 Go to previous messageGo to next message
1. I can't show you a picture, but we put the old 7m oil pressure in the passenger side of the block, above the engine number (sort of behind the air-con compressor if you got the motor out of a jza-70). Needed a couple of brass fittings to mount it at the right angle in the tiny space available. Works a treat.
2. The oil filter attachement does have water cooling where it bolts to the block. Most don't have seperate oil coolers, but I'd recommend you get one. Just get remote mount oil filter kit and cool the oil after it is filtered but before it goes back into the block. Plus then you can easily change oil filters with the cursing and screaming usually associated with doing it.
3. I can't remember Razz
Skip
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 07:17 Go to previous messageGo to next message
lumpy: My oil filter comes a fair way off the block, ends up facing backwards at a 45 degree angle. Where you placed the 7m oil pressure, is that the position of the original 1JZ sender? I can see three fittings going into the block on the passenger side, I believe 2 are knock sensors, the other I don't know. All have a single wire going into them.
lumpy
Adelaide, SA
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 07:31 Go to previous messageGo to next message
Ahh it's head scratching time now! The 1jz has a "low oil" sensor in the sump as well, but I can't remeber what we replaced on the side of the block. I'll have a look tonight but it's hard to see with the intercooler piping and air-con compressor in the way. May well have been the 1jz oil pressure sender for the "check" light that illuminates when you start the car. Come to think of it, it probably was Surprised !!
You need a right angled brass fitting to tuck the oil pressure sender behind the air-con pump. Made one with some brass fitting from local hydraulic hose shop. Make sure it's well tight though, otherwise it pisses oil out everywhere when you start it up. (like mine did Embarassed ) And it's a PRICK to change once the motor is in and the air-con pump on. Use loctite on all the threads etc etc.
We still have the "check" light working OK though - it's connected to the 7m oil pressure gauge.
My filter faces backwards as well, right under the inlet manifold. Pain in the arse to change it, as my hands don't fit under there.
Skip
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 08:02 Go to previous messageGo to next message
I know the sensor you are talking of, it is wedged in next to the aircon compressor. It was even a bitch for my to pull the plug off it when i tore off the wiring loom Laughing
STR8 2.8
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 08:05 Go to previous messageGo to next message
yes yes yes make sure u use some thread sealant or teflon tape or something,
no matter how tight i tightened the sender on my car it leaked, until i decided to use some tape Laughing
aha funny story b4 that, i had a T-piece to connect the gauge and the electric sender as well, but forgetting to screw in the sender leaving an open hole, started it up to see if the gauge worked....dumped several litres of oil all over my carport, engine bay, driveway and more argh such a mess. Mad
[Updated on: Wed, 15 October 2003 08:07]
Manny
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 13:14 Go to previous messageGo to next message
Or you can just fit a gauge like this http://www.mkiv.com/techarticles/oil_sensor_mod/in dex.html
82MKII
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 13:49 Go to previous messageGo to next message
So 1JZ's had an oil pressure switch (as opposed to an analogue sender)?
The reason I'm asking is my MA61 has an analogue dash (including an oil pressure gauge).
So is my best chance to see if the sensor from my 5MGE will screw into where the switch is on the 1J?
Is the oil pressure likely to be similar between a 5MGE (non-turbo) & the 1JZ?
(I'd try the new union bolt thing described above but I can't quite see what you are left with to screw a sensor into - looks like oil will come out of the head of the union bolt??).
Peter
Skip - sorry for hijacking you questions - you're in Perth so will have to catch up and compare 1Js
lumpy
Adelaide, SA
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 23:04 Go to previous messageGo to next message
I doubt it would screw directly in, but you could make it fit, and it would work with your oil pressure gauge OK. My MA70 is analogue dash and it works a treat. Idling oil pressure is ~2 Kg/cm2, under acceleration it goes up to 4.5 - 5.0.
That said, if I knew about the Union bolt mod, I'd have done it instead so much easier - but you'll probably still need to get a fitting to match the 5m sender to the Union bolt attachment. Oil comes out of the head of the Union bolt, which would be internally threaded to fit the stock oil pressure sensor.
Skip
Re: 1JZ Oil Pressure Gauge & Water cooling Wed, 15 October 2003 23:55 Go to previous messageGo to next message
Me scratching head over union bolt setup Confused
I have seen a screw in my oil filter bracket like the drawing, I think i will go remove it and check out what the thread is inside. I need only screw one gauge in, the original car is a diesel so im not too concerned about getting the factory gauge or warning light in the dash to work, the autometer gauge will do the trick.
Im glad im doing all this before putting the engine in!!!!
Skip
Re: 1JZ Oil Pressure Gauge & Water cooling Sun, 02 November 2003 23:27 Go to previous messageGo to next message
I pulled my aircon compressor of yesterday to get to the sensor. The sensor is huge Mad , not even a 1" ring spanner would fit over it, and there is absolutely no room around it due to block webbing. How do you remove it then, with a deep socket? If so what is the correct size?
Danish
Re: 1JZ Oil Pressure Gauge & Water cooling Mon, 03 November 2003 01:10 Go to previous messageGo to next message
I have just had an oil pressure gauge fitted and a water temperature gauge fitted recently to my 1JZ. I'll send you some pictures as soon as I get the car back this week.
I was going to get an oil cooler installed also however, i had to buy a seperate sandwhich or remote oil filter adapter to install the oil cooler too, and that was an extra $400 for labour and a parts, so i gave that a miss for now.
I couldnt work out the http://www.mkiv.com/techarticles/oil_sensor_mod/in dex.html article on self installing the gauge either!
[Updated on: Mon, 03 November 2003 01:13]
lumpy
Adelaide, SA
Re: 1JZ Oil Pressure Gauge & Water cooling Mon, 03 November 2003 01:41 Go to previous messageGo to next message
Do the union bolt instead of taking that sender off, it looks so much easier! Cool
Perhaps some-one who has done it can send in a photo of the completed bolt set-up. Or print the article out, take it to the engine and have a bit of a play around, head scratch until you understand what goes where. Keep in mind you will still need a fitting to go inot the head of the bolt and connect your 5m sender.
Re: 1JZ Oil Pressure Gauge & Water cooling Mon, 03 November 2003 01:47 Go to previous messageGo to next message
Manny wrote on Wed, 15 October 2003 23:14
Exactly what I did, but I never saw that article. Just drill a hole into the head of the bolt and get it tapped to suit your oil pressure sender.
Skip
Re: 1JZ Oil Pressure Gauge & Water cooling Thu, 06 November 2003 23:22 Go to previous messageGo to next message
I did what gianttomato said and drilled the end of the bolt to suit my Autometer gauge fitting. So if anyone wants a picture of it finished give me a yell.
Chris Davey
sunny coast, qld
Re: 1JZ Oil Pressure Gauge & Water cooling Fri, 25 February 2005 04:40 Go to previous messageGo to next message
*back from the dead*
I am wanting to install an oil pressure guage very soon. I have just had a look at my car and the oil light is staying on. I have been told that it will stay on if the electrical connection is not connected as it works as a ground. So where is the electrical connection for this?
Is this the sender you guys were speaking of before or is that different?
Regarding the union bolt mod, would that fit most aftermarket mechanical oil pressure guages?
Skip
Re: 1JZ Oil Pressure Gauge & Water cooling Fri, 25 February 2005 04:47 Go to previous messageGo to next message
The union bolt mod will fit any aftermarket mechanical or electrical oil gauge because you have to drill and tap the top of it to suit your fitting/sender.
Im sorry I cant answer your other questions I dont know where the existing electrical sender is on the 1J but you should just find the corona wire from the dash and earth that to the chassis.
Chris Davey
sunny coast, qld
Re: 1JZ Oil Pressure Gauge & Water cooling Fri, 25 February 2005 05:05 Go to previous message
Ok thanks Skip.
Don't worry about the idiot light question as I don't have any corona wiring left in the car.
Previous Topic:Ke70 (4k-c) Issues
Next Topic:Celica Ta22 and lowering the springs?
Current Time: Fri Nov 20 04:17:22 UTC 2026
Total time taken to generate the page: 0.0073421001434326 seconds
