Toymods » Tech & Conversions » W5X Spedo Drive Gear
wilbo666
W5X Spedo Drive Gear Wed, 15 October 2003 12:35 Go to next message
Hey guys, the W55 I've sourced had a 3.909 diff behind it, does that mean I HAVE to change the gear in the actual gear box or is the difference in the spedo cable that I have?
Also does it make any difference that my spedo cable has a 90 degree attachment where it screws into the gearbox (does this act like a ratio reducer / increaser?)
If I have to change the spedo drive in the box is it just a matter of removing the rear housing, or is it more complicated than that?
Re: W5X Spedo Drive Gear Wed, 15 October 2003 12:57 Go to previous messageGo to next message
Yes you have to change the nylon gears inside the box. You just need to remove the extension housing to get at them, not hard but a PITA when it's in the car.
wilbo666
Re: W5X Spedo Drive Gear Wed, 15 October 2003 13:33 Go to previous messageGo to next message
Gears? I though it was just one, see I've learned something already! Very Happy
Also I thought that some spedo cables had different numbers of teeth on them? Toyota the place to go or will they charge a testicle (i.e. anywhere better to go)?
So that 90 degree thing is just that, no gear reduction?
Cressida Supra
Re: W5X Spedo Drive Gear Wed, 15 October 2003 13:47 Go to previous messageGo to next message
only 1 gear, little plastic white thingy
and that 90 degree elbow just has cable in it
good luck finding the correct gear to suit you diff
the gear for w55/7/8/9 only comes in 32 and 33
i need a 36 to suit the 4.1:1 diff
looks like it will be custom
ed_ma61
Lost in the K hole
Re: W5X Spedo Drive Gear Wed, 15 October 2003 13:48 Go to previous messageGo to next message
ahhh crap - i hadnt considered this... bloody mkiv gear boxes... norbie, did you change your box's gears to suit the supra speedo? if so, did you just swap over the ones from the original w58?
otherwise, whats the final drive ratio in the mkiv NA manual? how fucked is my speedo going to be Confused
ed
82MKII
Re: W5X Spedo Drive Gear Wed, 15 October 2003 13:58 Go to previous messageGo to next message
Fellas,
try part # 33403-19235. Supposedly it is a 34 tooth & accoring to our local Toy dealers they can order it for $57.20.
I chased this up for mine (speedo reads 10% high & has a 32 tooth in it now), but never got around to buying one.
Once I put the 3.73 diff back in I will probably need a 33 tooth.
Peter
Cressida Supra
Re: W5X Spedo Drive Gear Wed, 15 October 2003 14:13 Go to previous messageGo to next message
34 hey? that still isnt quite enough
i'm running a 33, and its 9% high, so i need a 36 toother (33 x 1.09 = 35.97 - close enough)
any one have any idea how much it would cost to get a little plastic gear with 36 teeth on it made up?
wilbo666
Re: W5X Spedo Drive Gear Wed, 15 October 2003 15:08 Go to previous messageGo to next message
$57 Fuck me ay....for a little bit of plastic Sad
Anyone want to swap one from a 3.727 diff for a 3.909? Very Happy
So the number of teeth on the actual speedo cable doesn't vary?
Re: W5X Spedo Drive Gear Wed, 15 October 2003 16:13 Go to previous messageGo to next message
Peter,
Are you swapping a 3.73 diff back in? Whats wrong with the 3.9?
Re: W5X Spedo Drive Gear Wed, 15 October 2003 23:50 Go to previous messageGo to next message
What's all this about their being only one gear? The gear has to mesh with something, ie another gear, otherwise it doesn't do anything! It's the ratio of teeth between those two gears that's important here. Both of them can be changed to get the ratio you're after.
Ed: the NA MkIV 5-speed has a 4.0:1 diff ratio. I didn't swap the speedo gears in mine, but my Supra has a 4.1:1 diff ratio so it turns out the speedo is pretty close. I'm about to change my diff ratio to 3.5:1 though, so I'm going to have to do something about the speedo then!
Cressida Supra
Re: W5X Spedo Drive Gear Thu, 16 October 2003 00:20 Go to previous messageGo to next message
wilbo666 wrote on Wed, 15 October 2003 23:08
there arent any
its a key-way drive
ed_ma61
Lost in the K hole
Re: W5X Spedo Drive Gear Thu, 16 October 2003 00:57 Go to previous messageGo to next message
wilbo666 wrote on Thu, 16 October 2003 01:08
im now in need of a 3.909 if you feel like ofloading it once youve got the one you need Very Happy (although it is close to 4.0, so if i didnt change it, the speedo wouldnt be too bad...)
sorry, cant help you with the 3.727 though...
Cressida Supra
Re: W5X Spedo Drive Gear Thu, 16 October 2003 01:04 Go to previous messageGo to next message
correct me if i'm wrong, but wilbo's will be an E series diff? (mx62, solid axle etc)
82MKII
Re: W5X Spedo Drive Gear Thu, 16 October 2003 05:02 Go to previous messageGo to next message
JCMF - nothing wrong with the 3.9. I just think that once the 1JZ goes in the 3.73 will result in less wheelspin (ie only 1st & 2nd Smile ).
Norbie - you are correct about there being two gears. But the plastic one (driven gear, 32 - 34 tooth) is a piece of cake to change (can be done from under the car) with the box in the car.
The other one (11 or 12 tooth if memory serves me right) is a PITA. So if I can get the ratio close enough with a new driven gear I will go with it.
Peter
Re: W5X Spedo Drive Gear Thu, 16 October 2003 05:41 Go to previous messageGo to next message
It's true that changing the gear on the output shaft is a PITA, but sometimes you have no choice, ie when you make a major change in your car's diff ratio. Note that it can still be done with the box in the car, but it's a bit messy. Smile
Re: W5X Spedo Drive Gear Thu, 16 October 2003 05:44 Go to previous messageGo to next message
82MKII,
Got any plans for the 3.9?
sideshow
Re: W5X Spedo Drive Gear Thu, 16 October 2003 07:05 Go to previous messageGo to next message
isnt the gear on the output shaft all the same no mater what diff u have
i know on datsun boxes its all the same
and u just change the speedo plastic gear
i have never heard of changing the output shaft gear to suit a different ratio on a diff
Cressida Supra
Re: W5X Spedo Drive Gear Thu, 16 October 2003 07:11 Go to previous messageGo to next message
while you could prolly get aaway with not changing the gear on the output shaft, to change the speedo gear from say 29 to 36 teeth, it would no longer match up well with the output shaft gear
hence slowly chew the plastic gear out
how long this will take is anyones guess
and fwiw, w50/40 gboxs are pressed onto the output shaft and not easily removeable at all
sideshow
Re: W5X Spedo Drive Gear Thu, 16 October 2003 07:58 Go to previous messageGo to next message
well on datsun gboxes the plastic gear is offset in the speedo drive
so when u have one with bigger diameter the offset is more so it wont jam or fuk the plastic gears
im pretty sure toyota wouldnt change the gear on ht eoutput shaft
all they would do is change the speedo drive that slides into the back
u can see this by gettin 2 different sized speedo drives and checking if the offset is different
all u need to do is unbolt the speedo drive
and change it with a similar one but with different amount of teeth
just goto wrekers and try afew
Cressida Supra
Re: W5X Spedo Drive Gear Thu, 16 October 2003 08:13 Go to previous messageGo to next message
there are at least 3 different sizes of speedo gear, and they are not compatible with each other
and in each size, only a few different number of tech as available.
so matching gear to a diff that was never a combo from factory can be a problem
i had my w40 perfect, but it was just luck that it came with a speedo gear for the original diff/tyre combination that was obviouslythe same ratio as my diff/tyre combination
wilbo666
Re: W5X Spedo Drive Gear Thu, 16 October 2003 09:53 Go to previous messageGo to next message
Peewee, your saying that the diff actually has something to do with the setup? Shouldn't matter what series it is should it (I can't see how it could) unless that changes the number of teeth on the speedo cable / size of the speedo cable, is this the case?
Whats the best idea at the moment? To count the number of teeth in side the box, and the number on the speedo cable and try and work out what I need in the box to get close to 3.727?
At the moment, I'm thinking it might be easier to make a little box, so that if I change the tyres ratio a lot I can change it with little fuss....?
[Updated on: Thu, 16 October 2003 09:58]
Cressida Supra
Re: W5X Spedo Drive Gear Thu, 16 October 2003 13:15 Go to previous messageGo to next message
yeah wilbo, its mainly configured for the diff
although it is actually configured to the amount of road travelled per 32 turns of driveshaft (or 33 or 34 or whateva speedo gear you have)
so if you put bigger tyres on (diameter, not width), you will take less rotations of driveshaft for the same amount of road travelled, and hence you speedo will read lower than before
its the same with the diff, smaller ratio of teeth will make the driveshaft turn more for the same amount of road travelled, hence again the speedo will read lower
if your speedo is only just out, and you are up for new tyres, and you cant get the right speedo gear, it may be worth going up or down 5% profile
tho godknows what affect on the ride/handlin this will have!!!
wilbo666
Re: W5X Spedo Drive Gear Thu, 16 October 2003 14:03 Go to previous message
Do sa63's come with 185 / 70 / r14's standard?
If so the acutal diff ratio if I put it in my car with 185 / 75 / r14's is 3.79 apparently using this... if thats the case I'll be stoked!
Previous Topic:workshops in brisbane
Next Topic:help!! 4age ecu connector plugs
Current Time: Sun Nov 1 05:02:09 UTC 2026
Total time taken to generate the page: 0.0069689750671387 seconds
