Toymods » Tech & Conversions » Driving lights legality NSW
nicked
icon5.gif  Driving lights legality NSW Wed, 15 October 2003 12:36 Go to next message
I just spent about an hour on the RTA site.. i don't think i found anything that helped - but its got to be the most confusing website in the western world, so i cant be sure. Razz
From what I can gather, they are just a driver certified thing, and the only restriction on the legality of driving lights (NOT fog lights) is that they must be wired so they can't be on unless your high-beams are on? I've seen stuff about 600mm apart, 300-700mm off ground, but i think that's fog lights only.
Can anyone confirm or deny these allegations?
cheers,
Nick
4RS_FED
Re: Driving lights legality NSW Wed, 15 October 2003 13:05 Go to previous messageGo to next message
My VX Calais has driving lights from factory.
If driving lights were illegal, do you think GMH would be supplying them on standard cars?
I think common sense must come into play if a direct law on the RTA website can't be found. If you have driving lights that cause accidents because they are so bright they blind oncoming drivers, I think the police might show some interest in your setup. Other than that, they seem to be a fairly standard accessory.
Re: Driving lights legality NSW Wed, 15 October 2003 13:21 Go to previous messageGo to next message
you can have extra 'driving lights' hooke dup to your high beams, but high beams are generally illegal to use in built up areas..
the issue is that many ppl have the low mounted 'driving lights' hooked up to their low beams, and they create too much light that strays toward driver eye level.
LOL, there is an issue about the legality of either falcon or commodore 'driving lights' on one of the last models... they are actually too bright to be parking lights, and too low to be headlights, so can only be called 'driving lights'.
a number of ppl have been booked for having them on, even tho they are woired up from factory to go with the low beams.
the manufacturer had said that they would not accept responsibility for tickets issued for the lights....
afaik, low beam can consist of only two 55w lights, and high beam is meant to be limited to 60W per globe (so those 90-120W globes sold at K-mart are in fact illegal)
anyhoo,
BlackSupra
Re: Driving lights legality NSW Wed, 15 October 2003 13:28 Go to previous messageGo to next message
But in theory you would need a new relay to run those higher wattage globes.
Independantly switched driving lights are illegal.
nicked
Re: Driving lights legality NSW Wed, 15 October 2003 13:33 Go to previous messageGo to next message
thanks Smile
don't worry, they're not for jerking off in built up areas.
The uni year is nearly done which only means one thing - get the fork out of sydney.. & the combo of cruddy AE82 lights with my gf's driving is not inspiring on some dark & twisty country track Confused
edit: how did you know i bought them from kmart tonight? Very Happy 20% off..
[Updated on: Wed, 15 October 2003 13:34]
Callifo
Gawler, SA
Re: Driving lights legality NSW Wed, 15 October 2003 13:40 Go to previous messageGo to next message
Parents Calais have had quite a few warnings about having the driving lights on even though they came standard with the car. Just because they came on the car doesnt me your allowed to use them, according to the police anyway...
Re: Driving lights legality NSW Wed, 15 October 2003 13:44 Go to previous messageGo to next message
i think a lot of folks confuse 'driving lights' with 'fog lamps'. One is a spot light, the other is a coloured, wide-angle flood lamp with minimal vertical dispertion.
In Qld, only 'fog lamps' can be wired to power up on low-beam - but should only be used in rain/fog to increase safety and visibility (of your car and objects on the road). they're not be used in general driving conditions.
i'm not sure how many of youz folk drive around the burbs with super bright fog/driving lamps on, but it pisses me off. They produce massive amounts of (dangerous) glare. Most of the lights wired up as 'fog lamps' are just cheap-as-shit halogens floods from supacheap/kmart/other.
Seeing as a lot up of drive sportz cars with seats lower to the ground than usual cars, we're already more likely to be blinded by pooly adjusted headlghts - please don't add to that light pollution with irritating mini-floodlights.
charles.
Levin4Kevin
Sydeny
Re: Driving lights legality NSW Wed, 15 October 2003 14:56 Go to previous messageGo to next message
Just briefly. These lights you talk about are not illegal to the best of my knowledge, its just when they are used at the wrong times. I have been told that its not an offence to have these lights on during the day, but they will attract a fine if used at night.
The offence is something about the lights dazzling other drivers and this is obviously more so at night. I think most of the people who drive around with these lights on, would be for looks only. And I agree, I think they look good when on. But not at night.
Scud
Re: Driving lights legality NSW Wed, 15 October 2003 21:58 Go to previous messageGo to next message
4RS_FED wrote on Wed, 15 October 2003 23:05
Check your manual, they are fog lights which are wired to the parkers. When you switch them on (using the dash mounted switch) they turn on with the park lights.
Mate of mine got done on Thursday driving to Bathurst in his VX SS. $76 fine for driving with fog lights on during the day. It is definitely an offence in NSW to drive with foglights on when there is an absence of fog.
The issue of driving vs fog lights is quite confusing (and very emotive). Driving lights as I understand are wired into the high beam circuit. Operating only when you have your high beams on.
Me, I personally don't care if people use them or not. I had a sliver VX SS and I never switched mine off (in VIC it isn't illegal to drive with front fog lights on). Safety. With all the Commodore's running around with them on I never had a problem with the brightness of others therefore I assume the whingers who complain about the lights "hurting their eyes" have overly sensitive eyes and should consider some of those sexy sunglasses the oldies like to wear (sort of like welders goggles).
[Updated on: Wed, 15 October 2003 21:59]
gtman
Re: Driving lights legality NSW Thu, 16 October 2003 01:57 Go to previous messageGo to next message
Anyone who drives with fog lights on when there is no fog deserves to be shot. Worst offenders imho, excel drivers. The roundy excels that where a dime a dozen at one stage have rear fog lights that the idiot drivers don't even know exist, and more then 50% of them I'd say have them on with their low beams. Makes it freaking impossible to see when the have their brakes on when you're following them Mad
coronamark2
Re: Driving lights legality NSW Thu, 16 October 2003 02:17 Go to previous messageGo to next message
why use any lights at all when its not dark? Rolling Eyes
you see people driving around with there lights on during the day and think what a fkn tool.
wagonist
Toymods Club Treasurer
Re: Driving lights legality NSW Thu, 16 October 2003 02:29 Go to previous messageGo to next message
What's the problem with driving with lights on during the day. My car is silver & when out on the highway, its almost invisible without some lights on (usually my fog lights).
There are stats that prove it is safer.
I always have my front fogs on, mainly because the headlights aren't that good & I like to be able to see where I'm going. Plus I make sure they're aimed properly so as not to blind others.
Spotlights, driving lights, or high beam are not illigal to use in built up areas, just in the vicinity of other vehicles.
I agree with the rear fog light pain. Mad My car has one but it doesn't have a permanent switch (ie when lights are turned off & then back on, the rear fog doesn't automatically switch back on) I usually "flash" mine at offenders after I've passed them. I think the only success I've had with this method was from a BMW driver.
Says something about the mental capacity of Excel drivers. Laughing
coronamark2
Re: Driving lights legality NSW Thu, 16 October 2003 02:35 Go to previous messageGo to next message
Do you seriously think it makes a differnce to visability during the day?
Unless its real early in the morning and the suns just coming up or its starting to get dark at night i cant see the point in having them on, ohh well each to there own (im not starting a debate here)
wagonist
Re: Driving lights legality NSW Thu, 16 October 2003 02:44 Go to previous message
Green & Silver cars are the worst to be seen during the day because of shadows & reflection of sunlight.
It mainly occurs on the highway where you're travelling at high speed through trees.
Around town its pretty pointless though.
Previous Topic:18RG Flywheel Lightening
Next Topic:jzx90 wiring diagram?
Current Time: Mon Nov 2 18:13:24 UTC 2026
Total time taken to generate the page: 0.005810022354126 seconds
