Toymods » Tech & Conversions » Putting a distributer in?
raw_2t_power
Putting a distributer in? Wed, 15 October 2003 23:50 Go to next message
How Do I put A dizzy in? the engine was without one when i got it, so is it possible for me to put it in with simple tools and lack of an injury Very Happy
[Updated on: Thu, 16 October 2003 00:30]
raw_2t_power
Re: Putting a dizzy in? Wed, 15 October 2003 23:52 Go to previous messageGo to next message
oh and its a 2t with points, if that helps
raw_2t_power
Re: Putting a distributer in? Thu, 16 October 2003 22:59 Go to previous messageGo to next message
come on i have a fair idea how to connect it up but how do i know the distributor is in the right place, do i turn the crank till its TDC then point the rotor button to the first lead? can someone confirm this?
roger
Re: Putting a distributer in? Fri, 17 October 2003 00:01 Go to previous message
rotate the engine to top dead centre firing (You can check your cam position to do this or just assume you are on firing stroke). Place the dizzy in with the rotar pointing towards number one plug on the dizzy cap(you may need to mark the housing of the dizzy at the number one plug position). Try and start. Does it start or does it back fire? If it is back firing your dizzy is 180 degress out. Just swap the lead on the dizzy cap 180 degress ie if you firing strok is 1342 and the leads are configured like this
1 3
2 4 on the dizzy cap
the swap the leads to this
4 2
3 1
Not the firing order is the same but lead configuration is rotated 180 degress
Now start and time the engine.
Previous Topic:intercooler for a 4agte application
Next Topic:1jz jzx90 to jza70 computer
Current Time: Sun Oct 18 04:11:34 UTC 2026
Total time taken to generate the page: 0.025056838989258 seconds
