Toymods » Tech & Conversions » help!! 4age ecu connector plugs
DacBietAE86
help!! 4age ecu connector plugs Thu, 16 October 2003 07:04 Go to next message
Hey dudes..
Ive just bought a 86kw 4age complete wiring loom.
The standard 86kw 4age ecu has 3 plugs.
I can only see two plugs for the ecu on the wiring loom.
where is the third plug???
help please...
thanks guys
[Updated on: Thu, 16 October 2003 07:08]
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 07:15 Go to previous messageGo to next message
The 3rd plug was part of the body loom..
i think it had stuff for the dash/instruments and power, circuit open relay also maybe.
DacBietAE86
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 07:19 Go to previous messageGo to next message
arghhh...Im doing a 4age conversion into a 4ac sprinter.
so basically i need that 3rd connector then wire that connector into the body of the car correct??
Is that correct guys?
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 07:22 Go to previous messageGo to next message
Yeah just cut the plug out of another ae92/82 or something body loom.
Most the pins arn't used as water temp, tacho, oil, etc you'll use the original wiring for.
Get yourself a diagram that tells you what each pin does. But like i said above, use original 4ac body loom for most the stuff on that 3rd plug.
DacBietAE86
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 07:30 Go to previous messageGo to next message
thanks for your help TurboRA28 ..
Back to the wreckers for me!! hehe
sideshow
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 08:02 Go to previous messageGo to next message
hey joel
hey i have the plug u r looking for
give us 20 bucks and u can have it
DacBietAE86
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 08:20 Go to previous messageGo to next message
Hey dude...
Would you consider 10 bucks buddie?
Are the wires long off the plug??
Are you in sydney
REgards Van
sideshow
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 08:29 Go to previous messageGo to next message
ok
i have many wires if i need to fit them to the plug
is it the yellow plug with 12 wires on it?
even if its not i have few plugs here from sorted 4ags
DacBietAE86
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 08:32 Go to previous messageGo to next message
great!..Im going to pick up the ecu in a few days.Once i figure out which one i need i will call u to organise the missing plug.
Can i get your number and location so i can contact you
Thanks dudes..
Regards Van
sideshow
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 08:38 Go to previous messageGo to next message
cool
i live in baulkham hills
my num is 0415 904 947
Jim
im goin to be away from this monday for 2 weeks
should be back by 3rd or 4th nov
shindeokure
melbourne
Re: help!! 4age ecu connector plugs Thu, 16 October 2003 12:13 Go to previous message
go to a wrecker and or a yard and get one off an 89-91mdl camry for $5-10.
Previous Topic:W5X Spedo Drive Gear
Next Topic:3TGTE parts
Current Time: Sat Oct 31 13:16:22 UTC 2026
Total time taken to generate the page: 0.048971176147461 seconds
