Toymods » Tech & Conversions » manual vs. auto std ecu's
STR8 2.8
manual vs. auto std ecu's Thu, 16 October 2003 11:26 Go to next message
situation:
1jzgte or 2jzge into ma61 using w58
question:
what are the advantages of using a manual factory ecu compared to an auto ecu? is it worth spending extra to get a manual ecu?
Soarer
Wollongong
Re: manual vs. auto std ecu's Thu, 16 October 2003 11:38 Go to previous messageGo to next message
The auto ECU versions will retard timing when it thinks it's changing gear, lowering power output ever so slightly.
M/T versions don't do this.
(Based on 1JZ-GTE ECU knowledge)
STR8 2.8
Re: manual vs. auto std ecu's Thu, 16 October 2003 11:39 Go to previous messageGo to next message
so there isnt a huge difference
Re: manual vs. auto std ecu's Thu, 16 October 2003 13:41 Go to previous messageGo to next message
I've heard this said as well, but the ECU will never think it's changing gears when there's no auto transmission present. Smile
Some say the manual ECU is better, but I've yet to see a back-to-back comparison so I don't know if it's true or what the difference actually is.
Re: manual vs. auto std ecu's Thu, 16 October 2003 13:42 Go to previous messageGo to next message
Apart from the obvious problem of some ECU's going into limp home mode without the auto present. Take the example of Draven's car, ran fine with the manual ECU but ran limp home mode with the other.
Remedy
Southern Sydney
Re: manual vs. auto std ecu's Fri, 17 October 2003 21:04 Go to previous messageGo to next message
justcallmefrank wrote on Thu, 16 October 2003 23:42
still went hard though.
I think it ran supper rich too though.... like they run rich in the first place but more so.
STR8 2.8
Re: manual vs. auto std ecu's Sat, 18 October 2003 03:02 Go to previous messageGo to next message
yeh i was still super impressed with it in limp mode
ooo baby was i! Shocked
Re: manual vs. auto std ecu's Sat, 18 October 2003 11:46 Go to previous messageGo to next message
Its got a 1JZ, its bound to go hard, even when not running to potential! Smile
bbaacchhyy
Re: manual vs. auto std ecu's Sun, 19 October 2003 22:14 Go to previous messageGo to next message
Draven, (or anyone for that matter)
Anyone had experience converting from an auto to manual ? Confused
I'm about to do it, and would appreciate some help on specifics of running without Auto Trans ECU Very Happy
Michael B
Soarer
Wollongong
Re: manual vs. auto std ecu's Mon, 20 October 2003 01:58 Go to previous messageGo to next message
Gimme a few weeks and I'll be able to tell you. Soarer 1JZ-GTE auto to manual conversion is about to begin!
Re: manual vs. auto std ecu's Mon, 20 October 2003 03:57 Go to previous messageGo to next message
bbaacchhyy wrote on Mon, 20 October 2003 06:14
On the other hand, it doesn't seem to have been a problem at all in Norbies car...that thing is a machine...
bbaacchhyy
Re: manual vs. auto std ecu's Mon, 20 October 2003 04:35 Go to previous messageGo to next message
Norbie,
Can you please provide some help in dispensing with the A340E and transplanting the W58, in terms of disabling the Auto Trans computer, specifically avoiding the 'limp home' mode scenario ?
As a mechanical person, I'd love nothing more than the correct response of ".... just cut the loom and throw the computer away.." Very Happy Very Happy
Michael B
Re: manual vs. auto std ecu's Mon, 20 October 2003 06:25 Go to previous messageGo to next message
The Aristo doesn't have a separate computer for the auto; it's integrated into the engine ECU. I simply disconnected the plugs on the auto trans, unbolted it and replaced it with a W58. I was expecting problems with this approach, but everything ran perfectly without a hitch! I had the W58 speed sensor connected to the computer for a while, but I have since removed that with no ill effects.
Note that there are vast differences in the electronics between different cars with JZ engines, so the above may not apply to anything other than a JZS147 Aristo.
bbaacchhyy
Re: manual vs. auto std ecu's Mon, 20 October 2003 06:27 Go to previous messageGo to next message
Cheers Norbs, I'll give it a go and see what happens Very Happy
Not holding my breath tho' as it sounds too easy Confused
speakafreaka
Re: manual vs. auto std ecu's Mon, 20 October 2003 08:37 Go to previous message
make sure the transmission selector is set to park when youre doing the conversion (if using the auto ecu) or the car wont start when youve finished and you'll be scratching your head trying to work out why.
Previous Topic:Removing ae86 rear bumper
Next Topic:spark plug gaps
Current Time: Thu Oct 29 14:10:04 UTC 2026
Total time taken to generate the page: 0.0055339336395264 seconds
