Toymods » Tech & Conversions » 1jz coil packs and holders
1jz coil packs and holders Thu, 16 October 2003 13:45 Go to next message
Ive just pulled the coil packs on my 1jz - figure Ill pretty much rebuild the entire engine while its out
now apart from replacing all the screws that hold the coil packs to the brackets (2 of which burred and I need to drill out), what else should I do?
the brackets themselves are looking a little off, and one of them is slightly rusted. Im considering sanding them back, and was wondering if theres some sort of protective coat I could put on to stop corrosion/rust (also, what are they made of? steel?)
I think a simple clear lacquer coat wouldnt stand up to the temps, being right on top of the engine
any advice?
rob_RA40
c'town, NSW
Re: 1jz coil packs and holders Thu, 16 October 2003 22:05 Go to previous messageGo to next message
u will find that the lacquer will stand up to the temps under there.
most enamel paint is fine with block temps its only the exhaust manifold where u need the high silicone temp resistant paint.
Re: 1jz coil packs and holders Thu, 16 October 2003 23:16 Go to previous messageGo to next message
Ceramic coat them baby, yeah! Do the cam covers, in fact everything, while you're at it Evil or Very Mad Mightn't be cheap, but it lasts well and looks great Rolling Eyes
Skip
Re: 1jz coil packs and holders Thu, 16 October 2003 23:21 Go to previous messageGo to next message
When I removed my coil packs I left them on the brackets as I was begining to stuff the screw headed bolts up. I just pulled them out in pairs of two sitting on the bracket. Maybe some of that VHT paint would be fine. Did you pull the sparks out too Draven?
I really don't know whether I should replace my sparks (platinum) or not, theyve done 40,000kms, with conventional or platinum again. Ill be running wasted spark with the haltech so ill be wearing them out twice as quick, and as you know they are a biatch to change.
Is $20 a plug worth it?
Re: 1jz coil packs and holders Fri, 17 October 2003 00:52 Go to previous messageGo to next message
nup
ditch the plats and go for some standard sparks, just change them more often
and thanks for the info - hadnt really considered enamel painting them *ponders*
slylux
perth WA
    nup
Re: 1jz coil packs and holders Fri, 17 October 2003 12:32 Go to previous messageGo to next message
powder coat is cheap and very effective .. do the cam cover while ya ther .. would only cost lik 60 odd bux ..
Hey Skip .. u perth boy ... what ya haltech running??i need a map from ya ..
Skip
Re: 1jz coil packs and holders Sat, 18 October 2003 11:59 Go to previous messageGo to next message
slylux: Yeah im from Perth, ive got the new E6X. Im still in the middle of the conversion and therefore havent tuned the car yet, but I do have a 1JZ E6K map given to me by Haltech, to get me up and running. Would you like the E6K map?
slylux
perth WA
    nup
Re: 1jz coil packs and holders Sat, 18 October 2003 12:03 Go to previous message
hell yeah that would be awesome .. i didnt get a base map with my e6k .. so that would be a great help ... thanks man
Previous Topic:hilux gearbox xmember auto to manual
Next Topic:Alternators
Current Time: Tue Oct 20 22:54:31 UTC 2026
Total time taken to generate the page: 0.0089888572692871 seconds
