Toymods » General Car Talk » AE86 RCA and strut bar needed for sample
pepsicola
AE86 RCA and strut bar needed for sample Thu, 16 October 2003 15:39 Go to next message
I have the same idea as Simon-MrRx7's post.
As I am going back to China soon at the end of next month for holiday. (spent heaps money on ticket... Sad )
I think you guys would notice that things nowadays are all labelled "Make in China". The only reason is because the labour is so cheap, maybe lower than 1/10 of Australian labour. Cool
So I am looking for a set of RCA and strut bar as sample for me to take back to China. And I will see how much it would cost to machine up these parts. And I might be bringing back full case, 20kg of these parts hopefully. Very Happy
Anyone will volunteer to help? Rolling Eyes I can put money deposite to ensure I will bring back these parts.
[Updated on: Thu, 16 October 2003 15:40]
pepsicola
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 03:37 Go to previous messageGo to next message
i might only need measurement and probly a schematic diagram to do the RCA. it's only a piece of metal.
anyone?
and also does anyone know that if they are just plain aluminium?
cheers,
jin.
[Updated on: Fri, 17 October 2003 03:41]
shinybluesteel
melbourne
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 04:40 Go to previous messageGo to next message
they are just plain amuminium, but they have two sleeve type inserts (same as the struts)
you should ask someone for a spare sprinter strut, you could get all the measurements off that, as that is where they (the RCAs) fit afterall. just make them out of 30mm thick aluminium.
as for strut braces, i'd say it would be easiest to make one for an AE86, but they are pretty cheap to make here anyway i would think
pepsicola
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 05:19 Go to previous messageGo to next message
when u said the two sleeve type inserts, do you mean the two holes that the bolts go into?
that's one of the measurement I need to know as well.
I guess i will also need the overall dimension, bolt size.
And maybe I will as well ask to make ones with negative camber, so I need to know also how far dose the 2 negative camber holes apart from the original holes.
get the measurement straight from the strut would be a good idea, but i don't have access for one.
shinybluesteel
melbourne
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 07:10 Go to previous messageGo to next message
yeah, there are two holes, but on one side they have sorta location pins, with holes through the middle. take a look at a sprinter (or any) strut and you will know what i mean, or google for RCA, roll centre adjusters or whatever.
don't bother with the camber adjusters
pepsicola
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 09:15 Go to previous messageGo to next message
I have got heaps of the RCA pics, but i still don't get what u mean. Confused
can u like point it out in these pic?
http://www.ug.cs.usyd.edu.au/~jzhou/RCA/RCA4.JPG
http://www.ug.cs.usyd.edu.au/~jzhou/RCA/RCA5.JPG
http://www.ug.cs.usyd.edu.au/~jzhou/RCA/RCA_adj3.JPG
http://www.ug.cs.usyd.edu.au/~jzhou/RCA/RCA_adj4.JPG
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 09:22 Go to previous messageGo to next message
In the whiteline picture can you see the 4 little tube/collars? This are used to locate the strut onto the rca!
pepsicola
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 11:25 Go to previous messageGo to next message
ok, i get what u mean. So in the whiteline pic, the face that's showing up will suppose to fit onto the bottom of the strut, and in between that there will be some little tube/collars to align them.
am i correct?
Re: AE86 RCA and strut bar needed for sample Fri, 17 October 2003 11:31 Go to previous messageGo to next message
Yep you are correct! In the top picture you can actually see the collars fitted to the rca's already.
pepsicola
Re: AE86 RCA and strut bar needed for sample Sat, 18 October 2003 04:49 Go to previous messageGo to next message
why don't bother with the camber adjuster??
Re: AE86 RCA and strut bar needed for sample Sat, 18 October 2003 04:53 Go to previous messageGo to next message
Because adjustable control arms will work better in conjunction with the rca's!
pepsicola
Re: AE86 RCA and strut bar needed for sample Sat, 18 October 2003 13:51 Go to previous messageGo to next message
out of curious, if the car is lowered, what difference will u free before and after fitting the RCAs?
Ribbo
Northern Beaches
Re: AE86 RCA and strut bar needed for sample Sat, 18 October 2003 16:08 Go to previous messageGo to next message
pepsicola ive got a spare set of struts you could measure up if you want, I could bring them to uni and you could get them off me
pepsicola
Re: AE86 RCA and strut bar needed for sample Sun, 19 October 2003 06:13 Go to previous message
that's good.
we'll talk in icq later then.
Previous Topic:Cheap tow in Brisbane?
Next Topic:advice for resprays
Current Time: Fri Nov 20 19:43:32 UTC 2026
Total time taken to generate the page: 0.048341035842896 seconds
