Toymods » Tech & Conversions » Oil Light
rollaboy
Coffs
icon2.gif  Oil Light Sun, 21 July 2002 01:06 Go to next message
The Oil light on my ae82 flashes on and off most of the time.. Whats the go is it just a loss wire etc or something worse????
Brett
Re: Oil Light Sun, 21 July 2002 02:33 Go to previous messageGo to next message
might wanna check your oil levels? Smile
I know mine flashes on and off when cornering hard.. it's because there isn't much oil in it
RA23_Sean
Western Sydney
Re: Oil Light Sun, 21 July 2002 03:48 Go to previous messageGo to next message
The wire may have fallen off your oil pressure switch and is occasionally earthing out on your engine/body. If your light doesn't go on when you turn the ignition on, that could be your problem. Otherwise, check your levels.
shane11r
Re: Oil Light Sun, 04 August 2002 15:38 Go to previous message
Could be you pump on the way out or you pickup blocked. If you had the time and equipment you shoud hook up a gauge inside your car so you can monitor you pressure more closley
Previous Topic:5s cams in a 3sfe engien
Next Topic:KE20 Engine swap
Current Time: Thu Oct 22 05:04:52 UTC 2026
Total time taken to generate the page: 0.0046689510345459 seconds
