Toymods » Tech & Conversions » Port
benen
Port Fri, 17 October 2003 13:35 Go to next message
Can any of you ppl out there with ported engines tell me how much extra fuel you use compared to before it was ported and much it was ported?
ta23
Re: Port Sat, 18 October 2003 02:18 Go to previous messageGo to next message
If you are talking about what I understand to be ported it only increases airflow which in terms gives power, it doesnt mess with fuel consumption.
Re: Port Sat, 18 October 2003 02:48 Go to previous messageGo to next message
the diffreence will be linked to your right foot. when i ported my exhaust, i think consumption went down on highway runs (less exhaust restriction) but i've always had high fuel consumption figures Rolling Eyes
STR8 2.8
Re: Port Sat, 18 October 2003 02:56 Go to previous messageGo to next message
but if airflow increased wouldnt ur ecu crank up fuel to balance the air/fuel ratio?
Re: Port Sat, 18 October 2003 03:01 Go to previous messageGo to next message
porting does two things.
increases potential airflow
increases efficiency
but bad porting can also make both worse. even good porting may only increase efficiency and airflow potential in certain rev ranges too.
actual airflow is ALWAYS controlled by your right foot. if you use the throttle lightly, you decrease your fuel consumption, simple as that.
cya, Stewart
STR8 2.8
Re: Port Sat, 18 October 2003 03:04 Go to previous messageGo to next message
haha but who is gonna do that! Laughing
benen
Re: Port Sat, 18 October 2003 15:54 Go to previous messageGo to next message
sorry, i was talking about porting the head, i should have been more specific
EMP-2TG
Carlingford, Sydney
Re: Port Sat, 18 October 2003 16:53 Go to previous messageGo to next message
the head will only flow as much air as the throttle body lets in
M.J.H
Re: Port Sun, 19 October 2003 04:52 Go to previous messageGo to next message
I use don't measure the fuel consumption but i can tell you that with the ported head it now has a heap more torque than it did before.
What sort of motor are you wanting to do this to?
gold28
Madrid - Spain
Re: Port Mon, 20 October 2003 01:53 Go to previous messageGo to next message
A ported head if done properly should reduce your fuel consumption is driven easily because you won't be needing as much throttle/fuel to get the required power.
Re: Port Mon, 20 October 2003 10:54 Go to previous message
Yah - anything that can reduce pumping losses is a good thing on all counts - but its naturally a big question of tuning, driving style, etc. as well Evil or Very Mad
Previous Topic:3SGTE INTO A N/A MR2, WHAT AM I UP AGAINST
Next Topic:18rg cam timing
Current Time: Thu Oct 29 15:22:13 UTC 2026
Total time taken to generate the page: 0.005573034286499 seconds
