Toymods » Tech & Conversions » Anti-lag setup??
qik22
Anti-lag setup?? Fri, 17 October 2003 13:45 Go to next message
for lack of a better description its an anti lag setup... basically a diesel injector in the exhaust manifold that squirts a constant flow of fuel into the exhaust manifold while not on boost. the fuel is meant to burn creating flames which expand and create more gasses to help the turbo spool up quicker. has anyone attempted this before? is it as effective in practice as in theory?
TE72_Turbo
Re: Anti-lag setup?? Fri, 17 October 2003 14:30 Go to previous messageGo to next message
Ideally you would need to retard timing significantly as well (up to 30 degrees) to ignite the extra fuel properly. I dont know how you would set this up without a programmable ECU....
qik22
Re: Anti-lag setup?? Sat, 18 October 2003 02:19 Go to previous messageGo to next message
i have a haltech with direct fire so no dramas there
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Anti-lag setup?? Sat, 18 October 2003 02:29 Go to previous messageGo to next message
Make sure you have a supply of cheap turbos too, as it dramatically reduces turbo life.
Re: Anti-lag setup?? Sat, 18 October 2003 02:46 Go to previous messageGo to next message
qik22 wrote on Fri, 17 October 2003 23:45
you mean just like the WRC rally cars?? if you have ever heard the pops and bangs from the exhuast on decel (kinda like rifle cracks), then you can imiagine what it does to their turbos...
yes it will work, no your turbos won't last long....
Re: Anti-lag setup?? Sat, 18 October 2003 03:18 Go to previous messageGo to next message
Needless to say this is highly illegal and VERY conspicuous. As mentioned above it kills turbos in no time flat, which is OK for WRC teams with millions of dollars in the budget, but not so good for normal people tooling around the suburbs.
mx83toy
Re: Anti-lag setup?? Sat, 18 October 2003 04:54 Go to previous messageGo to next message
or buy a "celicamad" boost controler for 300 bucks Smile
ChuckLandwehr
Re: Anti-lag setup?? Sat, 18 October 2003 09:52 Go to previous messageGo to next message
Honestly, I dont think there will be sufficient oxygen left in the exhaust stream to support combustion. The anti lag systems on the rally cars also requires that the throttle be set open a few degrees above what they consider normal idle. The computer is then programmed to drop ignition off a couple of cyinders. Known as rotating misfire. The extra air and fuel mixture from the unignited cylinders, is then available for the combustion process in the turbo.Typically rally cars drive around 600 to 1200 K's per event.(including transport between stages) Turbos on a budget concious team are replaced every 3rd rally. 3,000 kilometers per turbo. Yeah like someone said, hope you have a very healthy bank balance. As they say in the rally fraternity "The way to make a small fortune from competitive motorsport, is to start with a large fortune."
truenosedan
Re: Anti-lag setup?? Sun, 19 October 2003 02:41 Go to previous messageGo to next message
just get a turbo of an evo 6, with a titanium moving parts less interia means less lag
Dabbid
Yowie Bay, Sydney
Re: Anti-lag setup?? Sun, 19 October 2003 05:55 Go to previous messageGo to next message
do u realise a diesel injector is not an electronic item
they are opened by excessive pressure supplied by the injector pump, so i dont think your haltech or anything will help
sideshow
Re: Anti-lag setup?? Sun, 19 October 2003 07:05 Go to previous messageGo to next message
antilag is cool
i used to run it on my 1600 with an autronic ecu
its magic when u change gears
it will fuk yr turbo
it can melt yr cat converter within 5 minutes
stress yr whole engine due to it running 20 to 30 degrees timing after top dead centre
and to get it running right takes awhile if u dont know what to look for
danielc
Re: Anti-lag setup?? Sun, 19 October 2003 09:16 Go to previous messageGo to next message
Dabbid wrote on Sun, 19 October 2003 15:55
the aux output would run a pump that would have enough pressure to open the injector and keep it squirting fuel
qik22
Re: Anti-lag setup?? Sun, 19 October 2003 09:21 Go to previous messageGo to next message
thats how i was going to do it
Re: Anti-lag setup?? Sun, 19 October 2003 09:28 Go to previous messageGo to next message
Do you have any idea how much fuel pressure diesels run?
sideshow
Re: Anti-lag setup?? Sun, 19 October 2003 09:41 Go to previous messageGo to next message
sell the haltek and buy an autronic
it uses the main injectors to supply the extra fuel
the throttle is open 10% at idle which makes the engine rev hi
to counter this u have to retard the timing 40 to 60 degrees from normal
this brings the revs down to about 1500 to 2000 or so
it sounds mad
hehe
qik22
Re: Anti-lag setup?? Sun, 19 October 2003 11:33 Go to previous messageGo to next message
thanks guys something to think bout
Re: Anti-lag setup?? Mon, 20 October 2003 00:10 Go to previous messageGo to next message
Tell you what - if you don't give a rats arse about the law, want a lesser chance of blowing yourself sky high, don't want to make as much noise and save a fortune on turbo rebuilds, do it the easy way - nitrous! Evil or Very Mad
Dabbid
Yowie Bay, Sydney
Re: Anti-lag setup?? Thu, 06 November 2003 10:06 Go to previous message
from the few different sets of diesel injectors i've installed this week at work
a diesel injector operates between 100-135psi
it'd wanna be a pretty good fuel pump you're getting....
Previous Topic:Circuit opening relay - question just to verify
Next Topic:ATF question
Current Time: Thu Nov 19 18:43:37 UTC 2026
Total time taken to generate the page: 0.044489145278931 seconds
