Toymods » Tech & Conversions » 2tg/3t hybrid owners, have you had this problem
juzzo84
Hornsby, N.S.W
2tg/3t hybrid owners, have you had this problem Sat, 18 October 2003 06:01 Go to next message
this relates to guys who built there own hybrid motor. when in the building process, did the conrod cap bolts every touch the block of the engine when turning it over by hand!!!
thanks for your help guys!!!
justin
Grega
melbourne.victoria.austra...
Re: 2tg/3t hybrid owners, have you had this problem Sat, 18 October 2003 06:56 Go to previous messageGo to next message
justin i remember reading that some of the early blocks had this problem but the late ones (ie: the 2TGEU) didn't.
nothing a burr and dremel won't fix...(but don't go overboard)
juzzo84
Hornsby, N.S.W
Re: 2tg/3t hybrid owners, have you had this problem Sat, 18 October 2003 06:57 Go to previous messageGo to next message
it is a 2tgeu block that i am using, its on the crank that is the prob, its the bottom of the bore!
Jonny2TG
Tasmania
Re: 2tg/3t hybrid owners, have you had this problem Sat, 18 October 2003 13:33 Go to previous messageGo to next message
I am using a 3T block, so there is no way I would have a problem like that myself. But like the other guy said, just grind the block away where needed.
juzzo84
Hornsby, N.S.W
Re: 2tg/3t hybrid owners, have you had this problem Sat, 18 October 2003 23:02 Go to previous messageGo to next message
yeah, it should not be a problem, i just wanted to know if anyone else has suffered the same fate!!!
justin
hemi twofifteen turbo
Re: 2tg/3t hybrid owners, have you had this problem Mon, 20 October 2003 01:45 Go to previous messageGo to next message
i'm in the process of doing the same thing,
haven't tried fitting the crank yet as i don't have the specs for
toqueing down the main caps litte ends etc.
My block is also a 2t-geu.
Is it possible your original block was blown up and the head and internals transfered to another 2t block?
I'll see if i get the same problem.. i hope not!!!
Re: 2tg/3t hybrid owners, have you had this problem Sun, 16 November 2003 03:11 Go to previous messageGo to next message
yep no problems with clearance.. 2t-geu block it must be.
juzzo84
Hornsby, N.S.W
Re: 2tg/3t hybrid owners, have you had this problem Sun, 16 November 2003 07:31 Go to previous message
sure is a 2tgeu block
Previous Topic:===> max wheel size for 91 cressida grande <====
Next Topic:Knock sensors.
Current Time: Tue Oct 27 00:48:16 UTC 2026
Total time taken to generate the page: 0.11473703384399 seconds
