Toymods » Tech & Conversions » heat up clutch fluid
pepsicola
heat up clutch fluid Sun, 19 October 2003 09:43 Go to next message
I am just wondering what will happen if the clutch oil is heat up by the exhaust manifold??
[Updated on: Sun, 19 October 2003 11:02]
Re: heat up clutch oil? Sun, 19 October 2003 10:40 Go to previous messageGo to next message
how to make an ass of yourself:
Step 1
Quote:
you have a wet clutch system?? wanna post pics??
Very Happy
[Updated on: Sun, 19 October 2003 11:30]
c2888
Re: heat up clutch oil? Sun, 19 October 2003 10:46 Go to previous messageGo to next message
Clutch Oil? Is this like blinker fluid? Laughing
I think you mean clutch fluid, which is brake fluid so I'd guess that if the line got hot enough it would boil too. Either wrap you exhaust with some sort of heat wrap material, or fabricate a simple heat shield between the two and you won't have to worry about it.
I had a sinking clutch pedal once, but it was due to bleed nipple coming undone. Burning brake fluid smells like butterscotch snapps. Very Happy
Daniel
pepsicola
Re: heat up clutch oil? Sun, 19 October 2003 10:48 Go to previous messageGo to next message
Laughing yeh i mean clutch fluid. i didn't know what i was thinking.
it's just that the clutch line is too close to the exhaust manifold. Crying or Very Sad
[Updated on: Sun, 19 October 2003 10:50]
Re: heat up clutch oil? Sun, 19 October 2003 11:09 Go to previous messageGo to next message
LOL, oops, i've been looking at too many bikes lately Wink
2 or 3 layers of exhaust wrap material will do the trick, will give it at least 5mm of fibreglass insulation.... how long do you need? i got a roll of 7.5m x 50mm wide (autospeed) recently, 1 length of that should cover it. (lay it along the length of the tube, and then wrap the width of the tape around the tube.. that make sense???
pepsicola
Re: heat up clutch oil? Sun, 19 October 2003 12:39 Go to previous messageGo to next message
i think i know the way to fix it, but just want to know how would the clutch react?
Re: heat up clutch fluid Sun, 19 October 2003 13:02 Go to previous message
if the fluid boils off, you'll have:
it's as if nothing had happened,
clutch not disengaging properly, or
no clutch at all
if you've really given the fluid a good boil off, it might be prudent to replace it as doing so makes it absorb moisture and other brake-fluid pollutants - plus it will lower the boiling point of the fluid making it not so useful as a hydraulic-power fluid.
charles.
Previous Topic:stock 18r-c valve sizes
Next Topic:which pistons for 2tg/3t hybrid
Current Time: Sun Nov 1 11:15:22 UTC 2026
Total time taken to generate the page: 0.005061149597168 seconds
