Toymods » Tech & Conversions » Lights
benen
Lights Sun, 19 October 2003 15:25 Go to next message
For some reason, just as i was coming home a minute ago. I started my car turned on my lights and there were no lights for my speedo and taco but there were lights for my petrol and temp etc. Also the heat and petrol gauge went right off the scale. Any ideas?
Also, when i turn on my high beam, the outside lights stay on but get brighter, the inside lights remain off.
Benen
blackRA28
adelaide
Re: Lights Mon, 20 October 2003 00:03 Go to previous messageGo to next message
Hey i experienced the lights not coming on behind the speedo/tacho before in my ra28, but still remaining on behind the temp/amp/oil/fuel/clock.. I have no idea what does it, becuase it was only happening 50% of the time for me.. could just be old wiring or faulty relays.. same with the headlight problem.. could just be wires decaying or a bad earth??
Follow the headlight wires to the fuse box or relays and test them if you can??
Maybe have it checked by an auto-electrician if you are not keen to investigate yourself..
Id be interested to know what causes these problems...
Good luck..
Guy
benen
Re: Lights Mon, 20 October 2003 12:19 Go to previous messageGo to next message
yeah its happened twice before aswell, i was on the way home another time and they came on half way home. Ill take a look tomorrow probably, if i cant figure it out ill get it looked at by an electrician. Ill let u know what it was.
Benen
Re: Lights Mon, 20 October 2003 12:28 Go to previous messageGo to next message
Wacky gauges and/or dash lights almost always means a bad earth, either under the dash or between the battery and chassis. This is quite common in old Celicas. Check all your earths and clean any corrosion, repair any breaks, and beef them up a bit with thicker wire if necessary.
benen
Re: Lights Mon, 20 October 2003 12:29 Go to previous messageGo to next message
if that were the case it would have to be the one under the dash if the other lights stay on right?
Byatch
Re: Lights Mon, 20 October 2003 12:32 Go to previous messageGo to next message
this would also explain why my gauges rise as soon as i turn on my headlights? it seems that as soon as more load is placed on the electrics, the gauges rise..
benen
Re: Lights Mon, 20 October 2003 12:37 Go to previous messageGo to next message
lol so its not just me. Ill see tomorrow if it is still doing it and the gauges rise only when i turn on my lights.
Re: Lights Mon, 20 October 2003 13:12 Go to previous messageGo to next message
my old RA23 would do this regularly.
fixed by repairing every visible/accessable earth connection in&out of car and replacing connector at back of alternator
sometimes you'll get a very faint alternator light - only visible at night with dash lights off
charles.
benen
Re: Lights Mon, 20 October 2003 13:30 Go to previous messageGo to next message
cheers charles. Now i have something to do tomorrow Smile What thickness wire should i use?
benen
Re: Lights Tue, 21 October 2003 04:25 Go to previous message
Im assuming there are separate earth wires for the lights and the dials since the dials still work. How do i get to the earth wires? and how do i find which wires to replace?
Benen
Previous Topic:Dash mat ae86
Next Topic:TIMING BELTS ON SW20 MR2
Current Time: Sun Oct 25 12:49:55 UTC 2026
Total time taken to generate the page: 0.0045070648193359 seconds
