Toymods » General Car Talk » 73 Corona MK2 front shock upgrade?
75rolla
Lynnwood, Wa USA
icon4.gif  73 Corona MK2 front shock upgrade? Sun, 19 October 2003 21:34 Go to next message
Hey all,
does anyone know or have any really good valved shocks for the front of my Corona MK2 Wagon? I am putting 92 Toyota Supra brakes with the spindles on my car and i would like some suspension behind it. After all, after about 130 MPH everything gets scary! the car floats like a boat.
I really hope i can get some Koni's of Tokico's Smile
thanx in advance!
coronamark2
Re: 73 Corona MK2 front shock upgrade? Mon, 20 October 2003 00:07 Go to previous messageGo to next message
ahh the boat styles of the mk2 dont u love it? Very Happy
All i can suggest is get new springs,shocks, and bushes and whatever else you can get Laughing
Re: 73 Corona MK2 front shock upgrade? Mon, 20 October 2003 03:14 Go to previous messageGo to next message
I have Koni reds in both of mine, front and back. It took a bit of work to get the big bore 55mm ones in the front - I had to enlarge the central hole and offset mount the lower shocker bolt holes. The smaller bore Koni Reds just slot straight in. It certainly helps with the boatiness.
Some springs will help .....probably 600 lb/in spring rate for the street (standard is only 220!).
I'd also recommend a good alignment - if you are seriously going to be spending that much time on the scarier side of 100 mph then get them to dial in a bit more caster (I am running 4 degrees). By using longer upper control arm bolts and a big shim (read big chunk of aluminium), I was able to get negative camber up to 4.75 degrees.
[Updated on: Mon, 20 October 2003 03:22]
75rolla
Lynnwood, Wa USA
Re: 73 Corona MK2 front shock upgrade? Mon, 20 October 2003 16:16 Go to previous messageGo to next message
So is negitive camber when the top of the tire is leaning in the fender? or is it when the bottom is deeper then the top.
Did that make sense? Smile
Also.. i was thinking that my springs were really tight. cause the car was ok withought shocks. so i figured with them it should help out a bit. I thought of getting some Koni's for the front with really good valving.
Anyone know were i can get some yellow KONI's?
Re: 73 Corona MK2 front shock upgrade? Tue, 21 October 2003 00:32 Go to previous messageGo to next message
Well I'm not in Washington state, in fact you'll see were all on the other side of the Pond. I am happy to supply you with details for the distributor here in Melbourne (Australia) if you want.
Negative camber is when the upper part of the tyre is further under the fender than the lower part. Positive camber is gay - the stock Mk2 actually has +0.5 degree camber dialled in as standard!!!
[Updated on: Tue, 21 October 2003 00:37]
Byatch
Re: 73 Corona MK2 front shock upgrade? Tue, 21 October 2003 14:50 Go to previous messageGo to next message
suppliers in melbourne you say?
now im interested......
where abouts in melbourne you live? might wanna chew the fat about how the conversion went...
Re: 73 Corona MK2 front shock upgrade? Wed, 22 October 2003 09:05 Go to previous message
Toperformance
1 Trade Place Nunawading.
Talk to Bastian.
I live in the Northern suburbs. PM or email me if you want to know more about the conversion.
[Updated on: Wed, 22 October 2003 09:06]
Previous Topic:Great service
Next Topic:most stupid bodykit
Current Time: Thu Oct 15 22:55:13 UTC 2026
Total time taken to generate the page: 0.31403994560242 seconds
