Toymods » Tech & Conversions » ae86 seat rails
shindeokure
melbourne
ae86 seat rails Mon, 20 October 2003 08:09 Go to next message
quick question:
is it possible to take the sliding part off a standard aus.spec sprinter seat rail without permanently damaging it (i.e. the bottom half of the rail)?
if so, how?
Callifo
Gawler, SA
Re: ae86 seat rails Mon, 20 October 2003 08:24 Go to previous messageGo to next message
The bottom piece of my rail was completely bent and had a ball bearing missing out of the centre. Tried to get it off but without drilling off the weld points I dont think so.
Tried myself and stuffed it up totally. Ended up getting a new bracket off a RA60 Celica and refitting that. The new bracket was slightly too wide so I drilled out a bit more of the hole and washered it back onto the body.
Re: ae86 seat rails Mon, 20 October 2003 09:07 Go to previous messageGo to next message
yes it is.
remove the entire rail, runner and holder, from the seat.
Drill out the little "bumps" at either end, which act as a stopper. Now with a little effort you should be able to slide the roller bearing+housing out of each end and thus remove the runner from the rail.
If you still wish to use the rail, then simply put a bolt where you drilled out the stoppers.
Callifo
Gawler, SA
Re: ae86 seat rails Mon, 20 October 2003 09:21 Go to previous message
Yeh thats what I had in mind when I started Laughing
Got it off for a reference but it was useless when I tried to put it back on.
Previous Topic:18rg cam timing
Next Topic:Removing ae86 rear bumper
Current Time: Wed Oct 28 22:43:15 UTC 2026
Total time taken to generate the page: 0.0123291015625 seconds
