Toymods » Tech & Conversions » Timing on 16v 4age HELP ME PLEASE.
ae95
Perth, WA
icon5.gif  Timing on 16v 4age HELP ME PLEASE. Mon, 20 October 2003 08:23 Go to next message
Hey,
I've now got all the info i need to do the timing on my car. But i cant find the diagnosis plug aka "check connector".
where abouts is it on a 4ac ae86 converted to 4age?
i've tried front left strut tower and firewall but cant find the damn thing. Im thinking the guy who did the conversion forgot to wire it up or something. I cant bypass the T and E1 terminals so there for i cannot stop the ecu controlling the timing, so no matter what i do the timing wont be accurate at all? what can i do
thanks guys
Sad Sad Sad
FKN16V
NSW, East Coast
Re: Timing on 16v 4age HELP ME PLEASE. Mon, 20 October 2003 11:09 Go to previous messageGo to next message
Which 4age is it.
Have you tried asking the person who did the conversion.
[Updated on: Mon, 20 October 2003 11:10]
TA22-3SGTE
MACKAY
Re: Timing on 16v 4age HELP ME PLEASE. Mon, 20 October 2003 11:20 Go to previous messageGo to next message
With the motor at running temp and at a normal idle set the timing to about 14 degrees , this is what it is without the connectors shorted .
Trevor
ae95
Perth, WA
Re: Timing on 16v 4age HELP ME PLEASE. Mon, 20 October 2003 12:23 Go to previous messageGo to next message
no one knows who did the conversion. is it accurate to adjust the timing without bypassing the terminals?
I noticed when i adjusted the timing to around 16deg BTDC and i revved the timing would change to 5deg the other side of zero
ae95
Perth, WA
Re: Timing on 16v 4age HELP ME PLEASE. Mon, 20 October 2003 12:24 Go to previous messageGo to next message
also, its a 4age 16v bigport tvis
ae82rollaboy
Re: Timing on 16v 4age HELP ME PLEASE. Mon, 20 October 2003 14:46 Go to previous messageGo to next message
hmmmm..
sorry dude, i also have a question about timing, so i thought i'd ask in your post, hope you dont mind Very Happy maybe both of us can get help.
ive got a bigport tvis 4ag and i cant even FIND the timing pulley. i was digging around under the bonnet with a timing light, until i nearly got an epileptic fit Freak Sleep Freak and i still couldnt find it.
so i ended up half-assedly advancing the timing straight off the dizzy, a few degrees at a time and taking it for a spin. when it started pinging i retarded it a few degrees and thats where its at at the mo..
could someone tell me whether this is ok? i cant hear it ping, but could it still be doing damage to the motor? and also, where exactly is the goddamn timing pulley anyway? it was sooooo easy to find on my old 4ac Shocked
=======cheers, roman===============================
Grega
melbourne.victoria.austra...
Re: Timing on 16v 4age HELP ME PLEASE. Mon, 20 October 2003 21:39 Go to previous messageGo to next message
have a look at the bottom where the crank protrudes at the front of the motor.
there is a pulley on that
on the plastic casing that goes around it, there is a series of timing marks on it.
on the very inside of the harmonic balancer (thats the thing attached to the front of the crank) there will be a little notch cutout in the balancer. this indicates your timing reference. point the timing light down there and you should see a line "line up" with the numbers on the cambelt covers.
hope this helps.
._T_.
Re: Timing on 16v 4age HELP ME PLEASE. Tue, 21 October 2003 00:23 Go to previous messageGo to next message
quite often when "rewiring" is done, the check connector is left out. this is a pain, but not a major issue - you will have to short out t1 & whatever the other pin is (which escapes me right now) at the ecu to set the timing correctly - which according to the manual is at 10 deg i think.
T
ae95
Perth, WA
Re: Timing on 16v 4age HELP ME PLEASE. Tue, 21 October 2003 05:08 Go to previous messageGo to next message
i know exactly where my ecu is, but which points do i short out? it doesnt state where the E and T1 terminals are.
ae95
Perth, WA
Re: Timing on 16v 4age HELP ME PLEASE. Tue, 21 October 2003 05:50 Go to previous messageGo to next message
I ripped my ecu out and took some photos of the plugs
Could someone please indicate which terminals to short.
http://groups.msn.com/_Secure/0QgDrAhgSHC!usgBFoxV 99NRCb4u18rZ4Gqfsqjj!3NxRMH96rgCdfoDZ4QCX3rbVNXlX4 aAgtI*DbeD4Ri4lHFTXsR4RlxM6Q7dNVyp8dQU/03102107.JP G?dc=4675443804471218315
http://groups.msn.com/_Secure/0QgAAABkSVS!usgBFoxV 99OpV6AY2Yhu4*jfsH6nv1pFJhMONq3aiM1dp0rc7Eb!WSqXBj HgHf7Gm4LSkJJcewZ*WwJ*1a!BZj8YhB2hfnOQ/03102108.JP G?dc=4675443804813649695
._T_.
Re: Timing on 16v 4age HELP ME PLEASE. Tue, 21 October 2003 06:11 Go to previous messageGo to next message
take the cover off the ecu - it will be stamped on the circuit board inside
T
ae95
Perth, WA
Re: Timing on 16v 4age HELP ME PLEASE. Tue, 21 October 2003 06:50 Go to previous message
Thanks heaps dude Very Happy Very Happy Very Happy
Previous Topic:1JZ-GTE JZX100 wiring diagram needed please.
Next Topic:1GGTE Wastegates or wastegate
Current Time: Fri Jun 12 13:15:57 UTC 2026
Total time taken to generate the page: 0.0052139759063721 seconds
