Toymods » Tech & Conversions » TPS to MAP sensor
ta23
icon5.gif  TPS to MAP sensor Mon, 20 October 2003 09:38 Go to next message
I currently have a 3TGTE running off a Haltech EMS. I have been told that it is running TPS and should be running MAP sensor. This can make a difference in turbo cars, how much power gain can I expect if I switch it to MAP sensor.
Re: TPS to MAP sensor Mon, 20 October 2003 09:51 Go to previous messageGo to next message
if you are running aftermarket ECU, and only have TPS, then you are running in aplha-N mode (rpm vs TPS). this is not real good at the best of times, and is usually only used on cars where the cam is so large that idle becomes a problem. i know the Wolf3D has a mode to have alpha-N at low rpm, and then speed density above.
for a turbo car, you should definitely be running either AFM or MAP, other wise, how does the motor know how much fuel to put in??
maybe have a look yourself and verify what it does and doesn't have?
power gain??? power gain from tuning all depends on how shit it is to begin with Wink
ta23
Re: TPS to MAP sensor Mon, 20 October 2003 11:42 Go to previous messageGo to next message
It is actually a turbo car with aftermarket Haltech and runs as TPS, which I know it shouldn't, I want to get it converted to MAP sensor but was wondering roughly how much power gain I can expect
[Updated on: Mon, 20 October 2003 11:43]
ta23
Re: TPS to MAP sensor Mon, 20 October 2003 13:23 Go to previous messageGo to next message
Anyone?
Re: TPS to MAP sensor Mon, 20 October 2003 13:31 Go to previous messageGo to next message
as i said man, it totally depends how bad the tune is now.
if it's on the money, you get no extra power. if it's totally crap, you might triple your power....
what do you want ppl to say???
having a map sensor will be much better as you can actually have a decent fuel table... just get the map, get it tuned properly, and it will be all good...
then agin, if you are happy with the drivability now, then leave it alone..
Re: TPS to MAP sensor Mon, 20 October 2003 13:52 Go to previous messageGo to next message
i'm am amazed that an installer would only wire up a TPS on a turbo? on F10's and E11's they're part of the factory kit.
without MAP it can't control boost, do boost-retarded ignition, do anti-lag, etc... correctly. It must be using heaps of petrol and a basic ign curve to keep it out detonation territory.
fwiw: you'll get much better fuel use, and better response under heavy accell and WOT if the ECU knows what's happening in the intake manifold with MAP.
any way, what you want is TPS AND MAP
Charles.
ta23
Re: TPS to MAP sensor Tue, 21 October 2003 01:15 Go to previous messageGo to next message
what is WOT? My car is using heaps of petrol and running fairly shit so that explains it, thanks for the replies
Re: TPS to MAP sensor Tue, 21 October 2003 01:19 Go to previous messageGo to next message
WOT is Wide Open Throttle - when you've got your foot to the floor Smile
ta23
Re: TPS to MAP sensor Tue, 21 October 2003 01:28 Go to previous message
ok, thanks Smile
Previous Topic:The next step for my 20V....
Next Topic:Dump pipes
Current Time: Sun Oct 25 17:29:58 UTC 2026
Total time taken to generate the page: 0.05609917640686 seconds
