Toymods » Tech & Conversions » speed sensors
Alainve
Newcastle NSW
speed sensors Mon, 20 October 2003 11:31 Go to next message
does anyone know what effect the speed sensor actually has on the management apart from having the obvious speed limiter
also is the speed sensor in an AE82 compatible with the ecu from an AE101?
FKN16V
NSW, East Coast
Re: speed sensors Mon, 20 October 2003 21:58 Go to previous messageGo to next message
Speed sensors let the computer know what speed the car is doing so that it can get the fuel map right for idle and speeds approaching idle amongst otherthings, My 4ag doesnt have it connected and the check engine keeps coming on, it does run little rich but im not worried.
Not sure about your other question thou.
Re: speed sensors Mon, 20 October 2003 23:46 Go to previous messageGo to next message
Yah, why IS it that so many people seem to not connect the bloody things? Evil or Very Mad
sideshow
Re: speed sensors Tue, 21 October 2003 13:14 Go to previous messageGo to next message
speed signal comes from the dash speedo
cars with carby engines dont have the speed signal due to different speedo
when i wire up carby cars with efi engines
i dont wire up speedo or ecu light cause if u dont do the speedo
wire then the light comes on
one way around it is to fit a newer speedo from an efi car
but if u leave it off on a 4a engine its ok
if u leave it of on a 1j and its auto then it might not change gear
jasonp1977
Re: speed sensors Tue, 21 October 2003 20:31 Go to previous message
If you leave the speed sensor disconnected on a 20V, it will rev-cut around 7500rpm instead of around 8250. Some of the factory carby dashes do have a reed switch output, there is just no wire in the plug for the output... eg Aus AE86 dash.
Previous Topic:What's THIS do?
Next Topic:DBA Slotted Rotors (715) For MK3 Supra - Want Them For GZ20 Soarer
Current Time: Fri Nov 20 21:52:59 UTC 2026
Total time taken to generate the page: 0.02006983757019 seconds
