Toymods » Tech & Conversions » Hi Flow CT26 + Lexus AFM/550's questions
rvrolla
Central Coast
Hi Flow CT26 + Lexus AFM/550's questions Tue, 21 October 2003 02:08 Go to next message
Hey!
A good friend of mine is going to do the Lexus AFM and RC 550cc's. But I have a few questions, that I am not completely sure about yet.
1) After market ECU is not required is it? It's just I have read on a few websites that people have after markets ecu's, and I'm just gathering its part of their upgrade proccess and not really a neccessity with the AFM upgrade.
2)Is a FPR required?
3)How much does a stock 7MGTE fuel pump flow? (1990 MZ20 Soarer) Would an after market pump be req. to feed the larger injectors? ie Bosche pump or something?
4)This will allow for much higher boost levels without FCD? And how high?
Ok, High Flow CT26 time:
1)What would be stock boost on one of these?
2)So far the engine has, a HK$ MHG, 7mGE cams, 3" turbo back mandrel, and a K&N Pod Filter. Is this enough to cop the extra oomph from the high flow?
3)Would it run ok on stock Intercooler?
Umm, thats all I can think of at this stage Smile But, I'm sure I'll be back with more Razz
Thanks guys!
EDIT: 550cc's not 500cc's Razz *smacks himself on the head*
[Updated on: Tue, 21 October 2003 02:19]
Re: Hi Flow CT26 + Lexus AFM/550's questions Tue, 21 October 2003 02:17 Go to previous messageGo to next message
1) No. The whole point of the Lexus upgrade is to avoid the installation of an aftermarket ECU or piggyback computer. It's basically a cheap and dodgy way of doing the same thing.
2) An adjustable FPR or RRFPR is recommended for fine-tuning, but it's not mandatory.
3) I would install a bigger pump for peace of mind. I'm not sure what the stock pump is rated at but you'd probably be pushing its limits if you maxed out the 550's.
4) Fuel cut will occur at much higher boost; over 20psi from memory.
rvrolla
Central Coast
Re: Hi Flow CT26 + Lexus AFM/550's questions Tue, 21 October 2003 02:21 Go to previous messageGo to next message
With a rising rate fuel pressure regulator, does it make the pressure changes automatically?
rvrolla
Central Coast
Re: Hi Flow CT26 + Lexus AFM/550's questions Tue, 21 October 2003 02:22 Go to previous messageGo to next message
p.s. thanks for the speedy reply mate ! Smile
Re: Hi Flow CT26 + Lexus AFM/550's questions Tue, 21 October 2003 05:39 Go to previous messageGo to next message
Yes; a rising rate FPR adjusts fuel pressure in proportion to manifold boost pressure. Some models allow you to adjust the manifold:fuel pressure ratio, but most are fixed.
Allan
Re: Hi Flow CT26 + Lexus AFM/550's questions Tue, 21 October 2003 16:42 Go to previous messageGo to next message
Norbie wrote on Tue, 21 October 2003 12:17
less dodgy then a FCD or crappy piggy back chip and probably also better then those S-AFC/f-con thingos
dont seem to hear complants from people that have done it!
Allan
rvrolla
Central Coast
Re: Hi Flow CT26 + Lexus AFM/550's questions Wed, 22 October 2003 01:35 Go to previous message
hrmm, ok, what if this particular 7MGTE already has a S-AFC? We were gonna set it back to 0 and get it re-tuned. I hope it works with the new setup, he spent allot of big ones on it ! Razz Rolling Eyes
Previous Topic:Need to borrow: Piston ring compressor...
Next Topic: Piston Ring Lubrication, Bed-In and HP
Current Time: Fri Nov 20 23:11:53 UTC 2026
Total time taken to generate the page: 0.0045959949493408 seconds
