Toymods » Tech & Conversions » Blocked ports and pipe on 16v 4age bigport tvis
ae95
Blocked ports and pipe on 16v 4age bigport tvis Tue, 21 October 2003 06:54 Go to next message
After i bought my car i found out that some of the pipes were purposely blocked and a vacuum port in the throttle body was also blocked. I took some pics of them to show you. One thing to note, when i unblock the port in the throttle body the car idles at 3k. Shocked when it is covered it stays around 1k -900
can someone please tell me what each pipe and port does and whether or not it should be connected?
http://groups.msn.com/Sprinta/shoebox.msnw?Page=La st
thanks once again
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Blocked ports and pipe on 4age bigport Tue, 21 October 2003 07:25 Go to previous messageGo to next message
How the hell is the port in the throttle body blocked? I'd be scared of the blockage coming loose & getting *schwooooop* sucked into your engine!
That port is for the idle up valve (which is that thing bolted to the underneath of the throttle body with all the blocked lines going into it), & supplies extra air to the motor while it's cold. When it's all working normally the motor should idle at 1500-2000rpm when you first start it, then slowly drop down to 800-1000 when fully warm.
By the sounds of it, the idle up valve is faulty, or you tested it while it was , or the coolant lines that connect to it from underneath have been disconnected, so it has no heat signal.
The rest of those blocked lines are for things like power steering, air conditioning etc, and aren't needed if you don't have any of that stuff.
Mine have always been blocked off too.
ae95
Re: Blocked ports and pipe on 16v 4age bigport tvis Tue, 21 October 2003 07:32 Go to previous messageGo to next message
The port is blocked by piece of electrical tape. i know its dodgy, im still trying to find something to jam into the hole. no wonder i have to hold the accel pedal when its cold Smile
what do i need to connect up to test if my cold start works?
[Updated on: Tue, 21 October 2003 07:34]
BigWorm
Turramurra, Sydney.
Re: Blocked ports and pipe on 16v 4age bigport tvis Tue, 21 October 2003 08:31 Go to previous messageGo to next message
Is there 2 coolant hoses going into the bottom of the t/b idle up valve?
ae95
Re: Blocked ports and pipe on 16v 4age bigport tvis Tue, 21 October 2003 09:45 Go to previous messageGo to next message
Can someone take a pic of where the hoses should connect to?
BigWorm
Turramurra, Sydney.
Re: Blocked ports and pipe on 16v 4age bigport tvis Wed, 22 October 2003 01:29 Go to previous messageGo to next message
2 pipes, about 5-10cm away from the blanked off pipes, pointing straight down.
ae95
Re: Blocked ports and pipe on 16v 4age bigport tvis Wed, 22 October 2003 06:14 Go to previous message
ill have a look when i get home
Smile Smile Smile
Previous Topic:want to make wiring harness for ae86
Next Topic:celica headlights outside pair work - inside pair don't
Current Time: Sat Oct 24 08:29:18 UTC 2026
Total time taken to generate the page: 0.0049140453338623 seconds
