Toymods » Tech & Conversions » balance shafts
benen
balance shafts Tue, 21 October 2003 13:18 Go to next message
can anyone tell me anything about balance shafts? One of my mates went and asked about getting them taken out of his sigma. Said u can get 30 more hp if they are removed. Even if it were the case i think itd be a waste of money on a pos like that. If they take away power and fuel economy then why do u have them? Also when did they start using them?
Benen
roger
Re: balance shafts Tue, 21 October 2003 22:26 Go to previous messageGo to next message
I know a little about this but not an expert. I have owned a sigma and a magna but have not removed the balanace shaft.
Removal will cause the engine to shack a little more. You can get the kits from repco appaerently.
If you balance the engine well during a rebuild it is unlikely that you will see any adverse effects. And you will see a slight power gain.
Advantages is less timing chains and a little more power. Little less weight (these things are heavy barstards and there is two of them and the chain)
Disadavantages are engine will shake a little at idle and higher revs if not balanced. Lot of work. Kit cost $250+. You have to block up oil galleries some how, some people have had problems in doing this resulting in low oil pressure. Again lot of work. If you are rebuilding an engine however you are crazy not to do it.
For some reason probably economical mitsubish feel the need to put these shafts in proably because they did not want the cost of balancinf a big four cyclinder but every other jap engine provided has not had the need to put them in a 2 litre engine! and porche has some big fours and do not have the need for such shafts.
Re: balance shafts Tue, 21 October 2003 23:20 Go to previous message
Can anybody say commodore V6 Evil or Very Mad C'mon Grega, we need you're input here Very Happy
Previous Topic: Piston Ring Lubrication, Bed-In and HP
Next Topic:turbo manifold ct26 for 4agze block
Current Time: Fri Nov 20 22:47:16 UTC 2026
Total time taken to generate the page: 0.0046570301055908 seconds
