Toymods » Tech & Conversions » ae82+gze temp gauge not working properly
twincam_ke20
Castlemaine Vic
icon13.gif  ae82+gze temp gauge not working properly Tue, 21 October 2003 21:01 Go to next message
Morning all.
yeh, since i put the gze in the temp guage hardly moves, sits nice and low unless its stationary and idleing, then the gauge moves to about half way, but never been over that.
is this right?
iv been told since it was a 4age twinky the guage would be set to that, and all i need is a 4age temp sensor and all is it, and it should go straight in to where the gze sensor is, is that correct?!
if so has anyone got a part number for one and a rough price?
twincam_ke20
Castlemaine Vic
Re: ae82+gze temp gauge not working properly Wed, 22 October 2003 11:00 Go to previous messageGo to next message
BUMP Very Happy
AE82TwinCam
Canberra, ACT
Re: ae82+gze temp gauge not working properly Wed, 22 October 2003 11:38 Go to previous messageGo to next message
Mine barely moves as well, its only hit 1/2 way once, on the way up the clide at crawling pace in 35degree heat.. otherwise when idling for ages it sits smack bang on the T of Temp, usually when driving it sits lower.. I figured if it did anything except that then there'd be something wrong so I don't even worry about it..
-Andrew
twincam_ke20
Castlemaine Vic
Re: ae82+gze temp gauge not working properly Thu, 23 October 2003 08:50 Go to previous messageGo to next message
sounds better then how mine opperates
hmmm, i just cant see how the old 4ag would be so different to the gze Rolling Eyes
Darola
Taree, 4h nth of syd
Re: ae82+gze temp gauge not working properly Thu, 23 October 2003 12:30 Go to previous messageGo to next message
hey mate how r ya?? my gze sits just under half all day every day, check your thermostat isnt stuck (as mine was from the half cut) and that your fan is cuting in and out, not always running, ive been told tat gze's r temp sensative, if the r running to cold they will stay in cold circuit mode
let me know how u go
Eddie
(Darola)
twincam_ke20
Castlemaine Vic
Re: ae82+gze temp gauge not working properly Thu, 23 October 2003 21:00 Go to previous messageGo to next message
Thanks darola
Anyone got a part number # for a thermostat for the 4agze, its a ae92 afm version.
Twinky
N.S.W
Re: ae82+gze temp gauge not working properly Fri, 24 October 2003 02:27 Go to previous messageGo to next message
Yeh mine sits just under half, takes ages to get there if the car is stationary the hole time, but soon as I take it for a drive it gets up to operating temp pretty quick.
Sounds like your thermostat is stuck open. It probably doesnt go over half way at idle because this is where your fan is kicking in???
Ive found with a GZE with no thermostat, it will as darola said stay in cold mode, gauge hardly moves and even after driving for ages, pull up at lights and it will idle higher.
From memory its the same as the ge thermostat, they dont vary in size much.
dimmy77_03
Potts Point, Sydney
Re: ae82+gze temp gauge not working properly Fri, 24 October 2003 08:00 Go to previous messageGo to next message
I've got pretty much the same thing on my Rolla. Takes ages to get up to just under half way coz its a carby. if u get stuck in a massive traffic jam and cruise in 1st every now & then it'll go just above half way. as soon as u start driving again it'll cool off.
AE82TwinCam
Canberra, ACT
Re: ae82+gze temp gauge not working properly Mon, 27 October 2003 07:46 Go to previous messageGo to next message
how would I go about checking if my thermostat is stuck then?
-Andrew
coronamark2
Re: ae82+gze temp gauge not working properly Mon, 27 October 2003 07:51 Go to previous messageGo to next message
im not to sure but follow the top hose from the radiator and it should be undeneath where the hose is hooked on to the engine there will be a couple of bolts undo them take it of there will prolly be a gasket so id get some gasket goo and i would advise drainin your radiator BEFORE you do this unlees you like coolant spilling evry where.
please 4age boys correct me if im wroung
twincam_ke20
Castlemaine Vic
Re: ae82+gze temp gauge not working properly Mon, 27 October 2003 09:16 Go to previous message
thanks for the replies people.
correct me if im wrong, im pretty sure the thermostat is on the bottom raditor hose.
i still cant understand why my old 4age never sat below half way and the 4agze hadly moves off the C line.
whats the temp rating for a 4agze/4age thermostat? does anyone have it off hand cos i dont really wanna drain my cooling sys and pull it apart to check.
maybe mines in 'cold mode' ?! my fan does cut in and out so that works fine
Previous Topic:steam pipe
Next Topic:niose suppressor
Current Time: Sat Nov 21 18:07:10 UTC 2026
Total time taken to generate the page: 0.0053119659423828 seconds
